1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS V4.7.0 C++ Bundle now available
To: EPICS tech-talk <[email protected]>
Date: Thu, 11 Jan 2018 14:18:11 -0600
I have just finished publishing version 4.7.0 of the C++ bundle of the
EPICS PVA (V4) modules. The code provided here is identical to the same
modules that have already been published as part of EPICS 7.0.1, but as
some of you may wish to use the PVA modules with older versions of Base
we are making that software available for building against Base 3.15.x
or Base 3.16.x.
The source code is available as a compressed tar-file or as a zip-file
and can be downloaded from
  https://github.com/epics-base/bundleCPP/releases/tag/4.7.0
or from the SourceForge files area at
  https://sourceforge.net/projects/epics-pvdata/files/4.7.0/
The module documentation for this release can be found on SourceForge at
  http://epics-pvdata.sourceforge.net/docbuild/4.7.0/index.html
This bundle release is C++ only, the Java modules were released back in
November as EPICS Java 7.0.0 and can be found under
  https://sourceforge.net/projects/epics-pvdata/files/7.0/
- Andrew
Prev: Re: Example for User Created File Types in the build system Jeong Han Lee
Next: PCASpy 0.7.1 Wang Xiaoqiang (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asynUInt32DigitalClient constructor Mark Rivers
ANJ, 12 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
