1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Latest version of adl2edl
Date: Sat, 13 Jan 2018 22:57:40 +0000
Folks,
I am working on a nice method to automatically convert medm screens to edm, caQtDM, and CSS that can be run with "make" in the op/ directory.  The conversion is quite slow, particularly for CSS, so I want to be able to use parallel make (make -j).  However, this does not work for edl2adl because it always uses a temporary file called adltemp.  It messes up if more than one instance of adl2edl is running at the same time in the same directory.
This should be pretty easy to fix, but I want to make sure I am fixing the latest version of adl2edl.  The version I am using is 1.4.6 from the Debian distribution.  Can anyone tell me whether this is the latest release.  Would it make sense to move this to the epics-extensions project on github?
Re: Latest version of adl2edl Kasemir, Kay
Prev: PCASpy 0.7.1 Wang Xiaoqiang (PSI)
Next: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Shuei YAMADA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Latest version of adl2edl Kasemir, Kay
ANJ, 16 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
