1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request]
To: Ralph Lange <[email protected]>
Date: Tue, 16 Jan 2018 10:06:22 -0600
On 01/15, Ralph Lange wrote:
> Dear Shuei,
> I have created https://bugs.launchpad.net/epics-base/+bug/1743321 to track
> this issue.
> Note, though, that Channel Access never claimed to be hardened. Even after
> fixing this behavior, an attacker on the local network will be able to
> cause all sorts of havoc by sending malformed network packages to CA
> servers and clients.
> Channel Access is not intended for use in a hostile environment.
I wouldn't call a port scan hostile.
Lewis
Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Ralph Lange
Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Shuei YAMADA
Prev: Re: Latest version of adl2edl Mark Rivers
Next: Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Ralph Lange
ANJ, 16 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
