1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC crash
Date: Thu, 18 Jan 2018 18:17:58 +0000
Hi Mark,
I'll try to find the core file. Thanks for the tip.
/Hinko
On Thu, 18 Jan 2018 at 13:31, Mark Rivers <[email protected]> wrote:
Hi Hinko,
Since it generated a core file you should be able to do some more debugging with gdb.  For example what are the values of "size" and pMsg->postsize in caserverio.c?  You might be able to figure out what PV this is.
From: [email protected] <[email protected]> on behalf of Hinko Kocevar <[email protected]>
Sent: Thursday, January 18, 2018 4:55 AM
To: [email protected]
Subject: IOC crash
Dear EPICS users,
here is the error I got from the IOC running EPICS base 3.15.4:
A call to 'assert(size <= ntohs ( pMsg->m_postsize ))'
    by thread 'CAS-event' failed in ../../../src/ioc/rsrv/caserverio.c line 357.
Dumping a stack trace of thread 'CAS-event':
[    0x7f4f3abf070b]:
/data/shi/R3.15.4/base/lib/linux-x86_64/libCom.so.3.15.4(epicsStackTrace+0x4b)
[    0x7f4f3abe9e1a]:
/data/shi/R3.15.4/base/lib/linux-x86_64/libCom.so.3.15.4(epicsAssert+0x3a)
[    0x7f4f3b0db512]:
/data/shi/R3.15.4/base/lib/linux-x86_64/libdbCore.so.3.15.4(cas_commit_msg+0x92)
[    0x7f4f3b0df468]:
/data/shi/R3.15.4/base/lib/linux-x86_64/libdbCore.so.3.15.4(read_reply+0x1d8)
[    0x7f4f3b0b82f4]:
/data/shi/R3.15.4/base/lib/linux-x86_64/libdbCore.so.3.15.4(event_task+0x1d4)
[    0x7f4f3abeaf5c]:
/data/shi/R3.15.4/base/lib/linux-x86_64/libCom.so.3.15.4(start_routine+0xdc)
[    0x7f4f38ca8e25]: /lib64/libpthread.so.0(start_thread+0xc5)
[    0x7f4f3931f34d]: /lib64/libc.so.6(clone+0x6d)
EPICS Release EPICS R3.15.4 $$Date$$.
Local time is 2018-01-18 11:27:33.597318519 CET
Please E-mail this message to the author or to [email protected]
Calling epicsThreadSuspendSelf()
Thread CAS-event (0x7f4ef804c510) suspended
CAS: request from 127.0.0.1:48578 => bad resource ID
CAS: Request from 127.0.0.1:48578 => cmmd=2 cid=0x1ce3 type=34 count=1
postsize=0
CAS: Request from 127.0.0.1:48578 =>   available=0x1058 N=0 paddr=0x7f4ec000c5e8
CAS: forcing disconnect from 127.0.0.1:48578
Segmentation fault (core dumped)
Hinko
.. the more I see the less I believe.., AE AoR
Re: IOC crash Michael Davidsaver
IOC crash Hinko Kocevar
Re: IOC crash Mark Rivers
Prev: Re: IOC crash Mark Rivers
Next: Re: Forcing make rule in IOC Makefile Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: IOC crash Michael Davidsaver
ANJ, 18 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
