My mistake. I had re2c 0.9.4, it didn't work. I used re2c 0.13.5, as suggested by Mark. Now i can compile successfully. With regards Vishnu From: Ralph Lange <[email protected]> Sent: Sun, 21 Jan 2018 22:34:30 To: EPICS Tech Talk <[email protected]> Subject: Re: Seq-2.2.5 compilation on windows On the installation notes for the sequencer (http://www-csr.bessy.de/control/SoftDist/sequencer/Installation.html), Ben has noted that re2c 0.9.9 is the minimum version required, so the documentation is fine.
@Ben: is there an easy way to add a check to the SNL build that would give a more obvious indication?
As always, thanks a lot for your help, Mark!
~Ralph
On Sun, Jan 21, 2018 at 5:41 PM, Vishnu Patel <[email protected]> wrote:
Hi Mark,
| ANJ, 22 Jan 2018 |
Home
News
About
Talk
Base
Modules
Extensions
