1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: PV Scan - Set values
To: [email protected]
Date: Tue, 23 Jan 2018 09:41:47 +0100
Hello everybody,
I'm wondering if it is possible to change the scan value to a value below 0.1 second, which is the lowest value explained in the documentation.
If not, there is another way of changing this value below .1 second??
Thank you very much for your answer.
Pilar Gil Jaldo
Seven Solutions | Embedded SW Engineer
2, Periodista Rafael Gómez Montero. Edf. CETIC-UGR, Oficina 13 - Planta 1 18014, Granada - SPAIN This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please immediately notify us via e-mail and delete it.
Re: PV Scan - Set values J. Lewis Muir
Prev: Re: How to work with motor record position counts larger than 2147483648? Torsten Bögershausen
Next: Re: PV Scan - Set values Anton Derbenev
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: PV Scan - Set values J. Lewis Muir
ANJ, 23 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
