1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC error
To: EPICS Tech Talk <[email protected]>
Date: Sat, 27 Jan 2018 11:55:17 +0100
Note that the screenshot shows the cbHigh thread failing the assert and getting suspended.
That would limit the candidate records to those with PRIO=HIGH.
Or - in the case of memory corruption - it would be a sign of memory corruption. (*Sigh.*)
~Ralph
On Fri, Jan 26, 2018 at 7:31 PM, Michael Davidsaver <[email protected]> wrote:
I think the assertion which is failing is at:
https://github.com/epics-base/epics-base/blob/3.14/src/db/dbNotify.c#L405
This code is involved with the CA put w/ callback operation.
The function dbNotifyCompletion() isn't called from many places in Base.
https://github.com/epics-base/epics-base/blob/3.14/src/db/dbAccess.c#L647
https://github.com/epics-base/epics-base/blob/3.14/src/db/recGbl.c#L259
In both places, the call is conditional on PPN!=NULL, which is what the
assert() is asserting.  So either dbNotifyCompletion() is being called
from some other code, or there is some memory corruption.
A stack trace should distinguish between these two possibilities.
IOC error Thomas, Patrick
Re: IOC error Kasemir, Kay
Re: IOC error Eric Norum
Re: IOC error Michael Davidsaver
Prev: RE: asyn IP server port driver with streamDevice Mark Rivers
Next: asyn R4-33 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IOC error Michael Davidsaver
Next: IOC build Vishnu Patel
ANJ, 27 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
