1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS database macro warning
To: Amien Crombie <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 31 Jan 2018 14:47:09 +0100
I actually use this 'bug' to selectively mask out certain parts of the database.
In the following example, if HS='#', the sequence selects "jog to limit". Otherwise, it "jog to home switch". Without this trick, I would need to create another record for this selection.
record(sseq, "INITSEQ")
    field (DOL2, "1")
    field (WAIT2,"Wait")
    field (LNK2, "TOLIMIT.PROC CA") # Jog to limit
$(HS)    field (LNK2, "TOHS.PROC CA") # Jog to home switch
If the 'bug' is useful, it probably becomes a feature.
Best
Xiaoqiang
On 01/31/2018 10:28 AM, Amien Crombie wrote:
Hi
I inadvertently stumbled upon this strange 'bug' in my ioc.db file
I had the following record:
record(subArray,    "$(uid):attenuator")
             field(INP,        "$(uid):raw")
             field(NELM,        "9")
             field(MALM,        "9")
             field(INDX,        "9")
             field(FTVL,        "LONG")
          #   field(FLNK,        "$(dd):getX")
Now the field '*FLNK*' is commented out and I have deleted my macro $(dd) in my substitution file.
When I run my IOC, I get the following warning
/macLib: macro dd is undefined (expanding string #    field(FLNK, "$(dd)")/
/Warning: 'db/dbExample1.db' line 16 has undefined macros/
So the comment (#) still evaluates the macro, even if the documentation says it ignores the whole line. Of course if the macro exist it runs without the warning.
Not a critical issue but can be misleading.
Thanks
Amien
EPICS database macro warning Amien Crombie
Prev: Re: EPICS database macro warning Ralph Lange
Next: Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Phytron Phymotion reset on IOC boot Nilson Pereira
ANJ, 31 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
