1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: ACalcOUT question
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 1 Feb 2018 10:23:20 +0200
Hi
I have the following record:
record(acalcout,        "$(dev):$(axis)_calc_offset")  {
        field(PINI,        "YES")
        field(DTYP,        "Soft Channel")
        field(NELM,        "48")
        field(INPA,        "$(dev):$(axis)range")
        field(INAA,        "$(dev):$(axis)_raw_cur.AVAL")
        field(INBB,        "$(dev):$(axis)_offset1.AVAL")
        field(INCC,        "$(dev):$(axis)_offset2.AVAL")
        field(INDD,        "$(dev):$(axis)_offset3.AVAL")
        field(INEE,        "$(dev):$(axis)_offset4.AVAL")
        field(INFF,        "$(dev):$(axis)_offset5.AVAL")
        field(INGG,        "$(dev):$(axis)_offset6.AVAL")
        field(INPA,        "$(dev):$(axis)_store_offset1")  # this is boolean 0 / 1
        field(OOPT,        "Every Time")
        field(DOPT,        "Use CALC")
        field(CALC,        "@@(@0)=AA")        # here Range is index to offset-Array of that range
record(waveform,    "$(dev):$(axis)_offset1")  {
        field(NELM,    "48")
        field(FTVL,    "FLOAT")
record(waveform,    "$(dev):$(axis)_offset2")  {
        field(NELM,    "48")
record(waveform,    "$(dev):$(axis)_offset3")  {
        field(NELM,    "48")
.......etc...
As you can see I have 6 Array link inputs (holding my 6 range noise/background/offsets)
What I would like to do is :
Take the 'range' as my index (so range 1=BB, 2=CC etc) and set it to my AA array.
When I run this I get nothing  in my waveform..
Amien
Re: ACalcOUT question Ralph Lange
Re: ACalcOUT question Amien Crombie
Prev: Re: Phytron Phymotion reset on IOC boot Torsten Bögershausen
Next: Re: ACalcOUT question Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: FLIR Spinnaker SDK: Request for input Jörn Dreyer
ANJ, 07 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
