I am replying to a rather old tech-talk post:
https://epics.anl.gov/tech-talk/2011/msg01310.php
I was attempting to use the histogram record type on epics base
R3.14.11. It threw the following errors when building:
- Record "TEST:Histo" is of unknown type "histogram" - Error at
or before ")" ...
- Missing device support entry table PV: TEST:Histo
histogram: init_record
To be able to use this record type, I had to install the record's
dbd in the application src directory.
1) Add histogramRecord.dbd to src/Makefile
ie. <App>_DBD += histogramRecord.dbd
2) Create a dbd file with following contents saved in src folder.
ie. Filename: histogramDeviceSupport.dbd
device(histogram,CONSTANT,devHistogramSoft,"Soft Channel")
3) Add above dbd to src/Makefile
ie. <App>_DBD += histogramDeviceSupport.dbd
4) Type 'make' in src directory
This recipe will allow the record type to work on base R3.14.x . The
record appears to have been corrected on base R3.15.x without
needing to added it to base.dbd.
Cheers,
Tim
Hi Mark,
On 2011-07-21 Vigder, Mark wrote:
> I started building an IOC using the histogram record and it gave me an
> "unknown type" error. I checked the source (I'm using EPICS 3.14.12) and
> even though the record is defined in <EPICSBASE>/src/rec it's not included
> in <EPICSBASE>/src/misc/base.dbd. In fact it's the only record defined in
> /src/rec that is not there.
> This leads me to a number of questions:
> -Is this just a bug? Or is histogram an obsolete record?
Interesting; I'm going to guess that you're not necessarily the first person
to *notice* this, but I think you're the first to point it out on tech-talk.
I don't believe the omission is deliberate, it's just that the histogram
record type is fairly specialized and is not used much any more. It it looks
like the last time anyone made any significant changes to the code (other than
just updating it to match API and coding style changes elsewhere in Base) was
in October 1998.
> -Does this mean nobody is actually using the histogram record?
I can answer that for the APS: we have a total of 4 (four) histogram records
across the whole of our 320-odd IOCs and well over half a million records in
our accelerator control system. Any other histogram users out there want to
speak up?
> -If nobody uses histogram, what do they use? Waveform?
I would guess other people are using subroutine or array subroutine records,
and for some uses just a calc or calcout record might suffice.
- Andrew
Re: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Johannes Spinneken (EGI)
Re: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Gabriel de Souza Fedel
<2018>
2025
2026
Re: 回复: Question about values of historic PVs dislpayed in CSS XY Graph widget Shen, Guobao
P4P release 1.0 (PVAccess for Python) Michael Davidsaver
<2018>
2025
2026
ANJ, 11 Feb 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
