Kiman,
The problem is that mathworks changed some of their mex functions in
2017b, making them incompatible with all but the most recent version of
labCA. In order to fix a previous incompatibility somewhere between
epics, matlab, windows, etc., a line was inserted for matlab,
mexLock();
around line 280 in ini.cc, located in the glue subdirectory. r2017b
changed the way that mexLock is called. This caused matlab to crash in
both linux and windows. This is the probable cause for the error you
have encountered. Till found that if we commented out the call to
mexLock he was able to get labCA to work in linux. I repeated the
experiment in windows7 and was able to get labCA to work there as well.
We made this change in our production systems, both linux and windows,
about a month ago and have seen no errors since.
I think that Till has very recently updated his labCA archive to reflect
this change, so the most recent version probably does not have this
problem.
/afs/slac/g/cd/swe/git/repos/package/epics/extensions/labca.git
But I would first try to just comment out mexLock();, rebuild labCA, and
see if your problem is solved.
Jim
RE: PMAC asyn autoconnect issue Mark Rivers
NSLS-II Debian Repository in 2018 Anton Derbenev
<2018>
2025
2026
Matlab crash with labCA 3.5.1 Ha, Kiman
<2018>
2025
2026
ANJ, 12 Feb 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
