1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Possible issue with epics-base 7 compilation
To: "'Gofron, Kazimierz'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 13 Feb 2018 00:36:59 +0000
Hi Kaz,
I don’t think this is a new problem, and is not specific to EPICS 7.  Are you using the make 4.1 that Andrew built and put on the EPICS Web page?
If I run “make –sj” with that version then it will occasionally get into a state when one “make” process is using 100% of a core forever and it never completes.  This happens with 3.14.12.5, 3.15.5, and 7.0.1.1.
I have never had a problem if I use “make –sj8” on my 8-core machine.
Sent: Monday, February 12, 2018 6:23 PM
To: [email protected]
Cc: Mark Rivers <[email protected]>; [email protected]
Subject: Possible issue with epics-base 7 compilation
There is a possible threading issue when compiling epics-base 7 using 'make -sj'  on 8 hyperthread system.
Observed on System X 3250 M5 with 8 hyperthreads, running windows 7 Professional, Xeon E3-1230 v3, and Visual Studio 2017.
make -sj never completes compilation
make -sj4 completes compilation
Compilation always successfully completes on Lenovo W550s laptop with 4 hyperthreads.
The two attached files show the two cases when compiling 'make' and 'make -sj' on the System X 3250 M5 (8 hyperthreads).
Kaz
RE: Possible issue with epics-base 7 compilation Gofron, Kazimierz
Prev: Possible issue with epics-base 7 compilation Gofron, Kazimierz
Next: RE: Possible issue with epics-base 7 compilation Gofron, Kazimierz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
