Hi Evan,
Note that the rate at which the PV updates and the rate at which the autosave file is written are quite different things. I don’t think it would use a lot of CPU for the
PV to update rapidly when the file is only being written every 30 seconds or so. But perhaps I am wrong?
Hello,
Apologies in advance if this is in the documentation somewhere, I was unable to find it.
We have an IOC which uses quite a lot of CPU when autosave is turned on. This is most likely the result of some inadvertently autosaved fields being updated at 100Hz. Is there a straightforward way, such as an IOC shell command, to print some debug output whenever
an autosaved field is written?
Best,
Evan
- Re: Autosave -- debug output when field is updated Mooney, Tim M.
- Autosave -- debug output when field is updated Daykin, Evan
Re: SMA100A Signal Generatordriver Nicholas P. DiMonte
RE: SMA100A Signal Generatordriver Ha, Kiman
<2018>
2025
2026
<2018>
2025
2026
ANJ, 13 Feb 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
