Hello:
>Is there any method to fix the vertical scale in "Inspect Waveforms" panel of the CSS DataBrowser?
>The vertical axis is always scaled automatically, and I cannot find the way to change it manually.
> I've tested with SNS version 4.5.0 (Basic EPICS).
If you use the latest download, the left-most plot toolbar button opens a configuration dialog for the axis range.
In addition, you can double-click on the start or end of the axis which turns the axis number into a text entry field where you can then enter the desired value.
-Kay
Description: wf.png
- Re: "Inspect Waveforms" in CSS DataBrowser Takashi OBINA
- "Inspect Waveforms" in CSS DataBrowser Takashi OBINA
CA Client crash after "too many open files" error Dirk Zimoch
<2018>
2025
2026
<2018>
2025
2026
