1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s)
To: 'Mark Rivers' <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 17 Feb 2018 13:03:09 +0000
Hi Mark,
The ADSupport compilation error is originating from non compatible UTF-8 characters in cmstypes.c file. That compilation error went away after changing characters to UTF-8 format.
For now, I placed a UTF-8 compatible file here:  https://github.com/kgofron/synAppsRelease/blob/master/SCRIPTS/ADSupportRepair/cmstypes.c
I wonder whether you have another installation of GraphicsMagick on your system.
The characters not following UTF-8 format are on following lines of cmstypes.c file. I checked few and they have 24 bit/6byte, instead of 2Byte(UTF-8). They are in comments area, and typically are left-quote/right-quote, ellipses single character (…), elongated minus, etc.
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c#L965
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c#L3063
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c#L3064
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c#L3066
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c#L3811
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c#L3898
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c#L4174
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c#L4673
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c#L4676
UTF8ó converter
https://sites.google.com/site/nathanlexwww/tools/utf8-convert
Line 965 1st non-compatible character uses left quote (Hex C293220A, RFC4648:wpMK).
-Kaz
Sent: Friday, February 16, 2018 11:46 PM
To: Gofron, Kazimierz; [email protected]
Ø  There is a compilation error when compiling ADSupport  of areaDetector 3.2 with base-7. This error is related to GraphicsMagic.
I cannot reproduce that problem.  I have rebuilt ADSupport several times and the strings “Malformed” or “UTF-8” do not occur in the output.  I used “make –sj8”.  I am using the master branch of ADSupport.
I am using the same setup as Kaz:
base-7.0.1.1
VisualStudio 2017
make-4.2.1
Windows 7 Pro 64 bit
windows-x64-static
I do note that by switching to make 4.2.1 I no longer see the hangup when using “make –sj” which I did see with make 4.1.  make 4.1 would always hang when building ADSupport/supportApp/hdf5Src with with make –sj.  It did always work with make –sj8.
From: [email protected] [mailto:[email protected]] On Behalf Of Gofron, Kazimierz
Sent: Friday, February 16, 2018 9:31 PM
To: [email protected]
Cc: Gofron, Kazimierz <[email protected]>
Subject: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s)
base-7.0.1.1
VisualStudio 2017
make-4.2.1
windows-x64-static
When compiling ADSupport, the following error is displayed twice:
Appending buf.obj
Malformed UTF-8 character (fatal) at c:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl line 136, <FILE> line 5573.
jbig.c
BZIP compiling as library
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]
(w) www.bnl.gov/nsls2
RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
Prev: RE: Dexela .dll missing when compiling WITH_PVA=YES Mark Rivers
Next: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
ANJ, 17 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
