1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Redirection question
To: Bruno Martins <[email protected]>
Cc: l123173 <[email protected]>, tech-talk <[email protected]>
Date: Mon, 26 Feb 2018 17:42:18 +0000
No spaces in the parameter list! (Sorry...)
Dirk
Am 26.02.2018 um 16:33 schrieb Bruno Martins <[email protected]>:
Hi Lixing,
Regarding:
2018/02/26 21:56:38.240082
_main_ devtemperature.proto line 9: Missing value for parameter $2
Your protocol function expects six parameters, $1...$6, but you are giving it only one ($1).
Try changing
field(INP,  "@devtemperature.proto getTEM(1) $(PORT) $(A)")
To
field(INP,  "@devtemperature.proto getTEM(1, 2, 3, 4, 5, 6) $(PORT) $(A)")
Bruno
On Mon, Feb 26, 2018 at 9:19 AM, l123173 <[email protected]> wrote:
Hi all,
     I wan to division the input string to several records.  I checked the subject of tech-talk about redirection.
     Then I modified my file as much as the same with the example in tech-talk. But still failed.
     So could someone give me some advice.
Typed: dbpf 1:getTEM 1
Get:
2018/02/26 21:56:54.551519 _main_ 1:getTEM: Record not initialised correctly
dbpf: Value conversion from STRING to DOUBLE failed
record(ai, "1:getTEM")
    field(DESC, "SCPI identification string")
#    field(SCAN, "5 second")
    field(DTYP, "stream")
    field(FLNK, "2:getTEM")
record(ai, "2:getTEM")
     field(FLNK, "3:getTEM")
record(ai, "3:getTEM")
field(FLNK, "4:getTEM")
record(ai, "4:getTEM")
field(FLNK, "5:getTEM")
record(ai, "5:getTEM")
field(FLNK, "6:getTEM")
record(ai, "6:getTEM")
getTEM {
    MaxInput = 17;
    out "\xFE\x04\x00\x00\x00\x06\x64\x07";
    in 0xfe 0x04 0x0c "%(\$1:getTEM.VAL).2r%(\$2:getTEM.VAL).2r%(\$3:getTEM.VAL).2r%(\$4:getTEM.VAL).2r%(\$5:getTEM.VAL).2r%(\$6:getTEM.VAL).2r%*02r";
# all message read back was hex.  It works well except a little qustion, if I just get one value(I mean %2r%*2r...). The little questiont: first inquiry could not get value, then all good.
    extrainput = ignore;
And the IOC output was:
## EPICS R3.14.12.7
## EPICS Base built Feb  7 2018
2018/02/26 21:56:38.240082 _main_ devtemperature.proto line 9: Missing value for parameter $2
2018/02/26 21:56:38.240147 _main_ devtemperature.proto line 9: in command 'in'
2018/02/26 21:56:38.240166 _main_ devtemperature.proto line 5: in protocol 'gettem'
2018/02/26 21:56:38.240197 _main_ while compiling protocol 'getTEM(1)' for '1:getTEM'
2018/02/26 21:56:38.240216 _main_ 1:getTEM: Protocol parse error
2018/02/26 21:56:38.240231 _main_ 1:getTEM: Record initialization failed
## Start any sequence programs
#seq sncxxx,"user=lyxHost"
Wishes,
Lixing
Redirection question l123173
Re: Redirection question Bruno Martins
Prev: RE: Excel DDE to EPICS interface freddie.akeroyd
Next: GE Pace5000/6000 and Teledyne ISCO D Series pumps Lionberger, Carl A.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Redirection question Bruno Martins
ANJ, 26 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
