1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ntndArrayConverter.h issue while ADCore compilation
To: Alper Kinaci <[email protected]>, "[email protected]" <[email protected]>
Cc: Sumit Kewalramani <[email protected]>
Date: Fri, 2 Mar 2018 12:21:27 +0000
Hi Alper,
What version of EPICS base are you using?  ntndarray.h is part of the "EPICS V4" or pvAccess code.  In versions of EPICS base prior to 7.0 the EPICS V4 code is a separate package that you need to build if you want to use it.  This is where it is located on my system:
corvette:/usr/local>find epics/epicsV4/EPICS-CPP-4.6.0 -name ntndarray.h
epics/epicsV4/EPICS-CPP-4.6.0/normativeTypesCPP/include/pv/ntndarray.h
On base 7.0 and higher it is part of base itself:
corvette:/usr/local>find epics-devel/base-7.0.1/ -name ntndarray.h
epics-devel/base-7.0.1/include/pv/ntndarray.h
If you want to use the pvAccess plugin or driver in areaDetector you need to set WITH_PVA=YES in areaDetector/configure/CONFIG_SITE* files.  If you are using base 3.x then you also need to define the locations of the PVA libraries in RELEASE_PATHS.local* and RELEASE_LIBS.local* like this:
# PVA modules
# For versions prior to EPICS base 7.0 use this
PVCOMMON=$(PVA)/pvCommonCPP
PVACCESS=$(PVA)/pvAccessCPP
PVDATA=$(PVA)/pvDataCPP
PVDATABASE=$(PVA)/pvDatabaseCPP
NORMATIVETYPES=$(PVA)/normativeTypesCPP
If you don't want to use the pvAccess plugin or driver then set WITH_PVA=NO in the CONFIG_SITE* files and it will not try to use them.
This is explained in the installation guide:
https://github.com/areaDetector/areaDetector/blob/master/INSTALL_GUIDE.md
Let me know if you have more questions.
From: [email protected] <[email protected]> on behalf of Alper Kinaci <[email protected]>
Sent: Thursday, March 1, 2018 6:06 PM
To: [email protected]
Subject: ntndArrayConverter.h issue while ADCore compilation
Dear All,
I am compiling ADCore from areaDetector 3-2 but I hit an error in compiling ntndArrayConverter.cpp. Please see below:
../ntndArrayConverter.h:2:26: fatal error: pv/ntndarray.h: No such file or directory
The header file ntndArrayConverter.h looks for pv/ntndarray.h but I couldn't locate this pv folder.
I appreciate any help. Thank you.
Best,
Alper
Alper Kinaci, PhD
Sr Computational Specialist
Research Computing Services
Information Technology
Northwestern University
[email protected]
847.467.7615
ntndArrayConverter.h issue while ADCore compilation Alper Kinaci
Prev: RE: striptool - was: Re: Idea for new Display Manager Andrew C. Starritt
Next: RE: Asyn not automatically reconnecting Daykin, Evan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ntndArrayConverter.h issue while ADCore compilation Alper Kinaci
Next: Communicate between XML-RPC system and EPICS Channel Access? Russell Kackley
ANJ, 02 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
