1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: StreamDevice with Telnet port
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 12 Mar 2018 06:49:47 +0000
Hi Mark
Thank you very much. I have just set these commands for all the controllers and waiting them to fail. But one thing I am not sure of is, how these captured information will help me?
Best Regards,
Abdalla.
-----Original Message-----
Sent: Sunday, March 11, 2018 3:15 PM
To: Abdalla Ahmad <[email protected]>; [email protected]
Subject: Re: StreamDevice with Telnet port
Hi Abdalla,
You should capture the communications stream between the IOC and the controller using asynTrace.  Type the following commands at the IOC prompt or put them in your startup script.  Replace PORT with the name of the drvAsynIPPort.
asynSetTraceIOMask PORT 0 2
asynSetTraceMask PORT 0 9
If it takes a long time to fail then you might want to send the output to a file
asynSetTraceFile PORT 0 filename
That trace should tell you if there was some miscommunication before the pressure PV comes back wrong.
From: [email protected] <[email protected]> on behalf of Abdalla Ahmad <[email protected]>
Sent: Sunday, March 11, 2018 7:54 AM
To: [email protected]
Subject: StreamDevice with Telnet port
Hi
We have the Gamma QPC ion-pump controllers controlled via StreamDevice through telnet, port 23. We have 4 parameters implemented, pressure, voltage, current, and channel status. The problem is that the IOC gives an error that the value received for the pressure PV is "Running", i.e. "Input Running does not match format %E". Seems like at some point the controller is not finishing a previous parameter and the IOC receives something different than the current parameter requested.
We have the following in the protocol file:
OutTerminator = CR;
InTerminator = CR;
ReadTimeout = 2000;
ReplyTimeout = 2000;
And each parameter in the protocol file has ExtraInput = Ignore at the end. Any help resolving this mismatching issue?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo<http://www.sesame.org.jo/>
Re: StreamDevice with Telnet port Mark Rivers
StreamDevice with Telnet port Abdalla Ahmad
Prev: Re: StreamDevice with Telnet port Mark Rivers
Next: Recipe for creating a new record Lucock, Richard M
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: StreamDevice with Telnet port Mark Rivers
ANJ, 12 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
