Thanks Andrew, you're correct!
(I actually even looked at one of those .d files)
Maren
On 03/13/18 18:29, Johnson, Andrew N. wrote:
Hi Maren,
You wrote “Before I changed the INSTALL_LOCATION to be outside the
source tree it built fine on linux-x86_64”. I suspect you didn’t do a
‘make clean’ when you added the INSTALL_LOCATION setting, and as a
result you have a lot of dependency files (*.d) in your
O.linux-x86_64 directories which depend on the old locations, i.e.
with the include directory inside the source tree. That explains why
the error message is from make (and not from gcc).
Try starting again from a clean source tree and I think (hope) you’ll
find the problem goes away.
- Andrew
- problem building 3.15.5 Maren Purves
- Re: problem building 3.15.5 Johnson, Andrew N.
Re: NSLS-II Debian Repository in 2018 Anton Derbenev
<2018>
2025
2026
SMOO expects constant Amien Crombie
<2018>
2025
2026
