1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to start EPICS IOC via LabVIEW on cRIO
To: "[email protected]" <[email protected]>, tech-talk <[email protected]>
Date: Thu, 22 Mar 2018 21:10:21 +0000
There is a slightly newer released version of lvPortDriver release last September that would be better to start with, as some bugs were fixed.
You should be able to build lvPortdriver as any other shared app, it requires epics base, asyn, and the labview header files.  The LabVIEW header files should be in the cintools subdirectory directory of your LabVIEW installation e.g. C:\Program Files (x86)\National Instuments\LabVIEW 2016\cintools  if you put those header files somewhere where lvPortDriver can find them (set the directory in your RELEASE file) then you should be able to build it.
Then you’ll want to build the IOC and include lvPortDriver.  Since I don’t usually build on the cRIO, I prefer to configure epics base for a static build, but either should work.  With a dynamic build all the shared libraries included with the IOC will have to be on the cRIO, and LabVIEW will just say error loading library if any of them are not found.
If you install the VIP file included with lvPortdriver (on your LabVIEW development machine) you can run the IOC using the VI that’s installed (page 6 of the talk you referenced).
Inside this vi is a Call Library Function Node, that runs the callmain function in the lvtest shared library (if you build your own IOC you’ll have to add this function, so that there is an externally callable function for the shared library instead of the main function of the IOC.
It also sounds like you may be having problems with running shared libraries from LabVIEW on Linux RT.  What I usually do is install the shared libraries in /usr/local/lib on the cRIO and then run ldconfig so that the cRIO will use the library.  ldconfig ?p can be used to verify the list of shared libraries that are loaded.
If you build everything statically, you can just name the IOC’s shared library liblvPortDriver.so and that’s the only shared library you need, or you can have multiple shared libraries.
Correspondence
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
From: [email protected] <[email protected]> On Behalf Of [email protected]
Sent: Thursday, March 22, 2018 1:43 AM
To: tech-talk <[email protected]>
Subject: How to start EPICS IOC via LabVIEW on cRIO
Dear tech-talk
I had a cRIO-9030 with NI Linux RT OSand had already built EPICS IOC (base-3.14) on the cRIO by PuTTY.
The only thing I want to do now is to start the IOC using LabVIEW instead of typing command via PuTTY. But the problem is coming.
Firstly, I tried to use "System Exec.vi" in LabVIEW to send command like "softIoc -d  xx.db", but it can not be  "continuous",
which means it will exit IOC shell soon once the process begin to run.
Next, I tried to use "lvPortDriver1.0" which is a software developed by LANS LLC:
In the ideal situation, IOC built as a shared library and be started from LabVIEW.
However, I have no idea to exactly built "lvPortDriver" on my cRIO, eventhough I have built asyn and modified ./configure/RELEASE
Then I just focused on the shared library producted by "lvtestMain.cpp". I used "g++" to compile ,link (with libCom.so in EPICS base),
and get a .so file. But when I use "Call library function node" in LabVIEW with the .so file, the IOC can not be started correctly,
eventhough there was no error in LV.(I can not monitor these PVs on my PC).
Does anyone have some detailed instructions for using "lvPortDriver" to start IOC as shared library?
Or any better option to start IOC via LabVIEW on cRIO?
Thank you very much!
Best Regards,
赵泽锋 (Zefeng Zhao)
Institute of Applied Electromagnetic Engineering
SEEE, Huazhong University of Science and Technology
Luoyu Road 1037#, Wuhan 430074, China
Email: [email protected]
How to start EPICS IOC via LabVIEW on cRIO [email protected]
Prev: measComp R2-0 released Mark Rivers
Next: RE: How to start EPICS IOC via LabVIEW on cRIO [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: How to start EPICS IOC via LabVIEW on cRIO [email protected]
Next: How to start EPICS IOC via LabVIEW on cRIO 赵泽锋
ANJ, 23 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
