1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynMotor: NewFocus 874x Picomotor Controller Driver
To: Torsten Bögershausen <[email protected]>, Angelic Ebbers <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 28 Mar 2018 11:54:02 +0000
Hi Angeleic,
The only error I could spot in your posting was this:
>     file "db/basic_asyn_motor.db"
>     pattern
>     {P,N,M,DTYP,PORT,ADDR,C,S,DESC,EGU,DIR,VELO,VBAS,ACCL,BDST,BVEL,BACC,MRES,PREC,DHLM,DLLM,INIT}
>     {lis:,1,   "m$(N)","asynMotor",MOT1,1,0,0,"Rot",counts,Pos,1750,500,1,0,0,50,1,0,0,0,""}
The substitutions line there should be M0, not MOT1.   You need to specify the name of the asyn port for the motor driver, not the TCP driver.
>     {lis:,1,   "m$(N)","asynMotor",M0,1,0,0,"Rot",counts,Pos,1750,500,1,0,0,50,1,0,0,0,""}
From: [email protected] <[email protected]> on behalf of Torsten Bögershausen <[email protected]>
Sent: Wednesday, March 28, 2018 1:27 AM
To: Angelic Ebbers; [email protected]
Hej Angelic,
I'm pretty sure that the usage of MOT1 is the problem.
You need 2 different asyn ports:
- one to communicate via TCP/IP to the motion controller
- the second to allow the generic model 3 driver (devMotorAsyn)
   to access the C++ classes in asynMotorController.cpp and
   asynMotorAxis.cpp
This is what I use:
#One:
epicsEnvSet("IPADDR",        "127.0.0.1")
epicsEnvSet("IPPORT",        "5000")
epicsEnvSet("ASYN_PORT",     "MC_CPU1")
#two:
epicsEnvSet("MOTOR_PORT",    "MCU1")
#And then for one:
drvAsynIPPortConfigure("MC_CPU1","127.0.0.1:5000",0,0,0)
asynOctetSetOutputEos("MC_CPU1", -1, ";\n")
asynOctetSetInputEos("MC_CPU1", -1, ";\n")
#And for two:
EthercatMCCreateController("MCU1", "MC_CPU1", "32", "200", "1000")
EthercatMCCreateAxis("MCU1", ...)
dbLoadRecords("./db/EthercatMC.template", "PREFIX=IOC:, MOTOR_NAME=m1, R=m1-,
MOTOR_PORT=MCU1,  AXIS_NO=1, DESC=motor1 ")
# And the template looks similar to this:
record(motor,"$(PREFIX)$(MOTOR_NAME)")
        field(DESC,"$(DESC)")
        field(DTYP,"asynMotor")
        field(OUT,"@asyn($(MOTOR_PORT),$(AXIS_NO))")
         [snip]
# (end of blabla)
So in your code
  nf874xCreateController("M0", "MOT1", 1, 200, 1000)
"M0" is "MCU1" in my example
"MOT1" is "MC_CPU1" in my example
And with that knowledge you should be able to use "M0" and "MOT1"
in the right way.
On 28/03/18 06:55, Angelic Ebbers wrote:
> Hi,
>      I'm working on supporting a New Focus 8743-CL controller at Gemini
> Observatory using EPICS/RTEMS.  I was thrilled to see that there already is a
> driver for the 8742 model controller in the motor distribution.  From my
> initial reading, I'm thinking there will be minimal changes needed to support
> closed loop control.
>       I've been trying to set up the driver, connected to the 8743, expecting
> that most functionality is the same as the 8742.  I seem to be doing something
> wrong, however, since the IOC crashes during/shortly after iocInit .. appearing
> to encounter problems during init_record.  The errors I'm getting seem to
> indicate a problem with how I'm setting up the driver support.  I'm following
> the example in "iocBoot/iocNewFocus874x".
>       Here are the errors I'm getting:
>     lis:m1Offset devAsynFloat64::initCommon findInterface asynFloat64Type
>     Bad init_rec return value  PV: lis:m1Offset ao: init_record
>     lis:m1Resolution devAsynFloat64::initCommon findInterface asynFloat64Type
>     Bad init_rec return value  PV: lis:m1Resolution ao: init_record
>     lis:m1Direction devAsynInt32::initCommon findInterface asynInt32Type
>     2018/03/27 17:09:45.730 devMotorAsyn::init_record, lis:m1 find int32
>     interface failed
>       I've done some digging on "devMotorAsyn::init_record find int32 interface
> failed" and found several TechTalk threads about trying to set up model 1
> drivers as model 3 (using asyn).  The specific problem in those cases was
> specifying DTYP as "asynMotor". (link to thread:
> https://epics.anl.gov/tech-talk/2013/msg02425.php
> <https://epics.anl.gov/tech-talk/2013/msg02425.php>)
>        I'm pretty sure I'm setting up the driver with the correct approach
> though and find no other clues as to the root of the problem.
> Here is my motor substitution file:
>     pattern
> relevant portion of my startup script:
>     ### Motors
>     # Setup IP port for 8742
>     drvAsynIPPortConfigure("MOT1", "10.1.60.111:23 <http://10.1.60.111:23/>")
>     asynOctetSetInputEos("MOT1",0,"\r\n")
>     asynOctetSetOutputEos("MOT1",0,"\r")
>     #db asyn debug traces
>     asynSetTraceMask("MOT1",0,0x9)
>     asynSetTraceIOMask("MOT1",0,0x2)
>     ## Load record instances
>     dbLoadTemplate("data/newfocus8742.asyn.motor.substitutions")
>     dbLoadRecords("${ASYN}/db/asynRecord.db",
>     "P="lis:",R=Asyn,PORT=MOT1,ADDR=,OMAX=80,IMAX=80")
> I've done a bunch of checking to ensure that my dbd has all of the asyn/motor
> support built in .. It seems ok.
> Here's the Makefile component:
>     gis-mk-ioc_DBD += motorSupport.dbd
>     gis-mk-ioc_DBD += devNewFocus.dbd
>     gis-mk-ioc_DBD += devSoftMotor.dbd
>     gis-mk-ioc_DBD += motorSimSupport.dbd
>     gis-mk-ioc_DBD += asyn.dbd
>     gis-mk-ioc_DBD += drvAsynSerialPort.dbd
>     gis-mk-ioc_DBD += drvAsynIPPort.dbd
>     gis-mk-ioc_LIBS += NewFocus
>     gis-mk-ioc_LIBS += softMotor
>     gis-mk-ioc_LIBS += motorSimSupport
>     gis-mk-ioc_LIBS += asyn
> Cheers,
> Angelic Ebbers
Re: asynMotor: NewFocus 874x Picomotor Controller Driver Angelic Ebbers
Re: asynMotor: NewFocus 874x Picomotor Controller Driver Torsten Bögershausen
Prev: PV gateway renders PVs as disconnected Abdalla Ahmad
Next: Re: PV gateway renders PVs as disconnected Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asynMotor: NewFocus 874x Picomotor Controller Driver Torsten Bögershausen
Next: Re: asynMotor: NewFocus 874x Picomotor Controller Driver Angelic Ebbers
ANJ, 28 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
