Hi Mark,
thank you for the answer.
On 29-03-2018 15:23, Mark Rivers wrote:
Hi Gabriel,
The Pilatus IOC receives an image from camserver that is already corrected for bad pixels and flat field.
Ok! And Can I set the flat field file (used on camserver) with pilatus ioc?
The IOC can do additional bad pixel and flatfield corrections if enabled. This feature may be deprecated and moved to the plugin layer in the future.
This adition bad pixel and flatfield correction cames from the IOC PVs
(flat field file, ...)?
Gabriel
Sent from my iPhone
On Mar 29, 2018, at 1:19 PM, Gabriel de Souza Fedel <[email protected]> wrote:
Hello,
Can someone explain if pilatus IOC modify the image generated by pilatus?
I would like to know how the flat field correction (from pilatus ioc) works. I think pilatus ioc doesn't use camserver flat field correction, that's right?
Thank you!
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Gabriel Fedel
www.lnls.cnpem.br
- Re: How Pilatus (ADPilatus) IOC process image Mark Rivers
- How Pilatus (ADPilatus) IOC process image Gabriel de Souza Fedel
<2018>
2025
2026
<2018>
2025
2026
