Hi Mark,
My colleague, Mitch informed me, there was similar discussion in 2016.
Thanks Mitch.
https://epics.anl.gov/tech-talk/2016/msg00941.php
I should search the tech-talk archiver first.
I will follow your comment in the discussion.
Thank you.
Best regards,
Kukhee
Kukhee Kim
SLAC National Accelerator Laboratory
2575 Sand Hill Rd, MS 64
Menlo Park, CA 94025
Email: [email protected]
Phone: (650)926-4912
Fax: (650)926-3800
-----Original Message-----
Sent: Friday, March 30, 2018 1:12 PM
To: 'Mark Rivers'; EPICS Tech Talk
Cc: Straumann, Till; Kurty, Thomas Charles; D'Ewart, J. Mitch; Williams Jr., Ernest L.; Weaver, Matt ([email protected])
Subject: force record processing for same parameter value in asyn port driver
Hi Mark,
I am using asyn port driver for LCLS1 mission readiness project,
and now am trying to integrate it with our Beam Synchronous Acquisition (BSA) system.
The BSA assumes, data source PV is processed every time, even the PV has same value with the previous processing, the PV should be processed and should have new timestamp. The new timestamp is an index key for the BSA.
I am using asyn port driver for the data source PVs.
In asyn port driver, if parameter has same value (no change), it does not make record processing.
Is there any option to make force record processing even no change on the parameter?
Thank you for your help.
Best regards,
Kukhee
Kukhee Kim
Email: [email protected] <mailto:[email protected]>
Fax: (650)926-3800
force record processing for same parameter value in asyn port driver Kim, Kukhee
CSS Combo Box Takashi OBINA
<2018>
2025
2026
<2018>
2025
2026
