1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Record to SCADA data exchange
To: EPICS Tech Talk <[email protected]>
Date: Fri, 13 Apr 2018 09:43:38 +0200
Hi Vishnu,
Wonderware/InTouch is mostly a client to hundreds of field buses and automation protocols, and while it should be possible, I don't think that adding Channel Access to their protocols is in their business interest.
However, according to their web site [1], InTouch has an embedded OPC (Classic) server.
Which means you should be able to push data into InTouch using the OPC (Classic) device support by HZB/BESSY [2].
Other that that, I don't see many options.
Cheers,
~Ralph
On Fri, Apr 13, 2018 at 6:09 AM, Vishnu Patel <[email protected]> wrote:
   Is anyone using EPICS to SCADA interface for data exchange?
In my application i am reading GPIB instrument data using stream device support. I also need to display some of records data to Wonderware SCADA.
I think it can be possible with TCP/IP communication but as i am read GPIB data with Stream device. I don't know how the record data can be pushed to TCP/IP or some related interface.
Thanks
Vishnu
EPICS Record to SCADA data exchange Vishnu Patel
Prev: Re: Which record is the best to use? Mooney, Tim M.
Next: Re: Which record is the best to use? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Record to SCADA data exchange Vishnu Patel
Next: Re: EPICS Record to SCADA data exchange Heinz Junkes
ANJ, 13 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
