1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with autosave module making it crash at random basis.
To: "Abdalla Ahmad" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 18 Apr 2018 11:57:55 +0000
> The core dump is generated but GDB could not show a backtrace and reported "missing separate debuginfo for the main executable file". Is it the case that the IOC should be built with debug symbols?
I have not seen that when building with the standard non-debug EPICS_HOST_ARCH of linux-x86_64.  It will warn that some system libraries don't have debug symbols, and some variables will be shown as "optimized out", but I have always been able to get a backtrace when it crashed.
Can you send the complete output when you start gdb and try to do a backtrace?
Sent: Wednesday, April 18, 2018 12:46 AM
To: Mark Rivers; [email protected]
Subject: RE: Problem with autosave module making it crash at random basis.
Hi Mark
Best Regards,
Abdalla.
-----Original Message-----
Sent: Sunday, April 08, 2018 4:01 PM
To: Abdalla Ahmad <[email protected]>; [email protected]
Hi Abdalla,
The latest autosave Makefile contains these lines:
# To enable autosaveBuild, use dbLoadRecordsHookRegister().  (Requires EPICS # base 3.14.12.5 or later.) USR_CFLAGS += -DDBLOADRECORDSHOOKREGISTER
Since you are running 3.14.12.3 I think you should try commenting out that USR_CFLAGS line.
With your older version of autosave your output showed that valgrind itself had crashed.  You should be able to get a traceback without valgrind, just by enabling core dumps.  Type the following commands:
On bash shell:
ulimit -c 10000000
or on csh shell:
limit core 1000000
Then run the IOC application.  When it crashes it will create a core.xxxxxx file.
Then run the Gnu debugger:
gdb path/to/your/IOC/executable core.xxxxxx
You need to provide the path to your IOC executable and replace core.xxxxxx with the name of the core file it just created.
Once you are in the debugger type:
backtrace
It will show a stack dump to where it crashed.
From: [email protected] <[email protected]> on behalf of Abdalla Ahmad <[email protected]>
Sent: Sunday, April 8, 2018 1:06 AM
To: [email protected]
Subject: Problem with autosave module making it crash at random basis.
Hi
One of our IOCs crashed and it appears to do so from time to time. I used valgrind on the IOC process and the attached file contains valgrind output right when the IOC crashed. The first 2 lines are the IOC shell output before the segmentation fault happened. I could not figure out whether the problem from the module sending something corrupted to the printf functions or the standard C library itself is somehow corrupted. I tried cloning the latest autosave version from github but the build failed. Build output is in the attached too.
OS: Scientific Linux 6.4 32-bit.
EPICS: 3.14.12.3
SynApps 5.6
Autosave 4.8
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo<http://www.sesame.org.jo/>
RE: Problem with autosave module making it crash at random basis. Abdalla Ahmad
Re: Problem with autosave module making it crash at random basis. Mark Rivers
Prev: Re: CSS xy graph question Jörn Dreyer
Next: RE: Problem with autosave module making it crash at random basis. Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem with autosave module making it crash at random basis. Abdalla Ahmad
ANJ, 25 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
