1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn4.33 compilation error on windows-64
To: "Ralph Lange" <[email protected]>
Date: 20 Apr 2018 09:28:50 -0000
Hi Ralph,
     Absolute path works  for me.
Thanks
Vishnu
Sent: Fri, 20 Apr 2018 12:21:33
To: EPICS Tech Talk <[email protected]>
Cc: Vishnu Patel <[email protected]>
Hi Vishnu,
Try setting an absolute path for your SUPPORT area (either explicitly or by using the $(abspath ...) make function).
Absolute paths work from any place in the directory tree, while relative paths work only from a specific level or location. This may cause the difference between finding your sequencer installation or not.
Cheers,
~Ralph
On Fri, Apr 20, 2018 at 7:34 AM, Vishnu Patel <[email protected]> wrote:
   It is already been configured in  RELEASE file
#RELEASE Location of external products
SUPPORT=$(TOP)/../
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
#  IPAC is only necessary if support for Greensprings IP488 is required
#  IPAC release V2-7 or later is required.
#IPAC=$(SUPPORT)/ipac-2-13
# SEQ is required for testIPServer
SNCSEQ=$(SUPPORT)/seq-2.2.5
#  EPICS_BASE 3.14.6 or later is required
EPICS_BASE=$(TOP)/../../base-7.0.1.1
-include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH)
and seq-2.2.5 has been compiled successfully.
Thanks
Vishnu
Sent: Thu, 19 Apr 2018 16:12:20
To: Vishnu Patel <[email protected]>, techtalk <[email protected]>
That error is happening because it cannot find the EPICS State Notation Language (SNCSEQ) compiler.  You must have defined SNCSEQ in your asyn4-33/configure/RELEASE file but not actually installed or built it.
Re: asyn4.33 compilation error on windows-64 Ralph Lange
Prev: EPICS Qt release 3.6.1 (and 3.5.3) Andrew C. Starritt
Next: Re: Possible deadlock issue with asyn layer? Davis, Mark
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn4.33 compilation error on windows-64 Ralph Lange
Next: Question about data browser of CSS. lzf neu
ANJ, 20 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
