1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: OPC UA Device Support - Requirements Doc
To: EPICS Tech Talk <[email protected]>
Date: Tue, 24 Apr 2018 13:58:24 +0200
Dear all,
As we have decided to officially add OPC UA to the supported interfaces in ITER's CODAC Core System, I have published the Software Requirements Specification version 1.0 that we will use for design and implementation.
This module is based on the prototype work of Bernhard Kuner at HZB/BESSY II and uses the C++ Based OPC UA Client/Server SDK by Unified Automation as low level driver.
Schedule: Design is under way; we expect to have a minimal implementation by the end of summer (tagged as milestone "0.9" in the SRS) and a full implementation by the end of the year. Code will be available on GitHub.
Cheers,
~Ralph
Prev: dbReadDatabase in base-7.0 Benjamin Franksen
Next: using epics-base with yocto Mariano Ruiz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dbReadDatabase in base-7.0 Andrew Johnson
ANJ, 24 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
