1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Modify checkbox value from a table widget
To: [email protected]
Date: Wed, 25 Apr 2018 10:03:27 +0200
Hello,
I'm having problem while trying to modify the checkbox value from a table widget from a python script. And I would like to know if it is possible to do it.
Write now I have a table:
    tab = display.getWidget("Table").getTable()
And for enable the checkbox I'm using following command.
    tab.setCellText( 1, 1, "Yes")
The problem that I have is that I can see "Yes" written on the table, but the checkbox is not enabled.
Has someone of you handle before with such a problem?
Thank you very much in advance!
Pilar
Pilar Gil Jaldo
Embedded SW Engineer
[email protected] - Seven Solutions
"This e-mail and any materials attached here to, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are confidential. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please immediately notify us via e-mail and delete it."
Re: Modify checkbox value from a table widget Pete Jemian
Re: Modify checkbox value from a table widget Kasemir, Kay
Stringin - asynOctedRead type how to set string length Pilar Gil Jaldo
Prev: RE: Problem with autosave module making it crash at random basis. Abdalla Ahmad
Next: Re: using epics-base with yocto Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Walking Piezo Drivers/ Controllers Survey Wallace, Alex
Next: Re: Modify checkbox value from a table widget Pete Jemian
ANJ, 05 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
