1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Wait for pv to connect sscan
To: tech-talk <[email protected]>
Date: Tue, 1 May 2018 23:35:11 +0800 (CST)
Hi Mark and all,
     I used sscan-2-10-1( 2D scan ), base 3.15.
     I always got "Waiting for pv's to connect" after I clicked the "scan" in scan1.
     But it work fine when I disable the saveData in st.cmd with the same setting. It could do the scan 1 and scan 2.
     So I think the error was saveData. But saveData should be easy. The error was "I/O error, can't open file" though I am root.
     The following was some strange message I got.
     When I set the parameters, I got these message in st.cmd.
dbpf("xxx:scan1.R1PV", "xxx:m1.RBV")
DBR_STRING:          "xxx:m1.RBV"
dbpf("xxx:scan1.P1PV", "xxx:m1.VAL")
DBR_STRING:          "xxx:m1.VAL"
dbpf("xxx:scan1.T1PV", "xxx:m2.EXSC")
DBR_STRING:          "xxx:m2.EXSC"
dbpf("xxx:scan2.R1PV", "xxx:m2.RBV")
DBR_STRING:          "xxx:m2.RBV"
dbpf("xxx:scan2.P1PV", "xxx:m2.VAL")
DBR_STRING:          "xxx:m2.VAL"
dbpf("xxx:scan2.T1PV", "XSPRESS3-EXAMPLE:HDF5:Capture")
xxx:scan2:special:connect already in progress for link T1.  Waiting...        (The sentence came out sometime, 50%)
DBR_STRING:          "XSPRESS3-EXAMPLE:HDF5:Capture"
dbpf("xxx:scan2.T2PV", "XSPRESS3-EXAMPLE:Acquire")
DBR_STRING:          "XSPRESS3-EXAMPLE:Acquire"
motorUtilInit('xxx:')
saveData_Init(saveData.req, 'P=xxx:')
saveData: message queue created
saveData:maxAllowedRetries = 10
saveData:retryWaitInSecs = 15
seq &scanProgress, 'S=xxx:, P=xxx:scanProgress:'
sevr=info Sequencer release 2.2.4, compiled Sun Apr 15 20:26:45 2018
sevr=info Spawning sequencer program "scanProgress", thread 0x26a0de0: "scanProgress"
# write all the PV names to a local file
dbl > dbl-all.txt
# Report  states of database CA links
#dbcar(*,1)
# print the time our boot was finished
date
2018/05/01 23:01:14.875178
asynSetTraceIOMask("L0",0,2)
asynSetTraceMask("L0",0,9)
sevr=info scanProgress[0]: all channels connected & received 1st monitor
    Source File: ../cac.cpp line 1298
    Current Time: Tue May 01 2018 23:01:14.903656005
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "XSPRESS3-EXAMPLE:HDF5:Capture", Connecting to: 192.168.0.1:5064, Ignored: 192.168.1.106:5064"
    Current Time: Tue May 01 2018 23:01:14.902491275
    Context: "Channel: "XSPRESS3-EXAMPLE:Acquire", Connecting to:
Then I click the stop button to stop. I saw these.
It should not be like these. I do have the permission since I am always root.
saveData: ...will retry in 15 seconds
saveData:writeScanRecCompleted(xxx:scan1): can't open data file!!
saveData: too many retries; abandoning data from scan 'xxx:scan1'
saveData: *******************************************
Li xing
Re: Wait for pv to connect sscan Mooney, Tim M.
Prev: Re: NSLS-II Debian Repository in 2018 Anton Derbenev
Next: Re: Wait for pv to connect sscan Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Are Stream Device protocol clauses atomic? Gregory, Ray
ANJ, 01 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
