1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: NDPluginFile attribute saving
Date: Tue, 1 May 2018 17:07:55 +0000
I have an areaDetector file plugin saving a specific HDF5 structure with multiple images in one file. I set attributes to be saved per image via NDAttributesFile. I'm currently using capture mode. At the moment each image seems to have the same parameter values; as at the point the file is written. Is there a way for the attribute values to be as they were at the point each image is collected? Maybe I missed something in creating the plugin, some other setting or the attributes XML file?
Thanks
Steve
RE: NDPluginFile attribute saving Mark Rivers
Prev: Re: Wait for pv to connect sscan Mooney, Tim M.
Next: RE: NDPluginFile attribute saving Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 01 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
