1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: combo dropdowns in CSS BOY
Date: Wed, 9 May 2018 12:37:28 +0000
Is there a way to modify the appearance of the dropdown in a combo widget in CSS BOY? The dropdown is not as wide as the combo itself (it appears to derive its width from the widest element in the dropdown list). Also, the background of the dropdown matches the background of the OPI so it doesn’t stand out very well. Finally, for a write-combo, if I set the background to ‘Write_Background’ (a cyan color), then much of the combo frame is still gray but the cyan color shows up in the selected text as well as around the frame. Is there any way to modify this?
Thank you,
--Ray
Prev: Re: How do you generate nexus files? Matt Newville
Next: Re: How do you generate nexus files? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How do you generate nexus files? Gabriel de Souza Fedel
Next: devAsynUInt32Digital: add parameter for shifting? Konrad, Martin
ANJ, 09 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
