1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How do you generate nexus files?
To: Matt Newville <[email protected]>
Date: Wed, 9 May 2018 16:25:29 -0300
Hi Matt,
On 09-05-2018 09:22, Matt Newville wrote:
Hi Gabriel,
On Wed, May 9, 2018 at 6:56 AM, Gabriel de Souza Fedel <[email protected] <mailto:[email protected]>> wrote:
    Here at Brazilian Synchrotron (LNLS) we are working to implement
    nexus on some beamlines. We are working with python, getting all
    data from epics PVs and build nexus files. On all the cases the most
    important data are waveforms.
    We would like to analyses other possibilities, and to verify how
    other synchrotrons generate nexus files:
    Do you are working with nexus files?
Yes, many beamline groups at the APS use nexus, especially in the sense that nexus is HDF5+naming conventions.
great!
    How do you generate them?
    Are you using some high level language for it (like python, c++) ?
From python, nexpy (https://github.com/nexpy/nexpy) is very useful for working with nexus data, either from plain python programs, or from its very nice GUI.  You can also sort of "roll your own" by using HDF5 + the nexus conventions.  That's probably not "recommended", but it can work in a pinch.
Hum, nice! I didn't know this library, I will take a look.
    Is it possible to generate nexus files using areadetector for
    instance (with more than one "source", including waveform) ?
Yes, there is a nexus plugin for areadetector.  In addition, the HDF5 plugin follows (as far as I know) the nexus conventions, and can also be discovered and handled well by nexus tools.
Thank you for the answers
Regards
--Matt Newville
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
How do you generate nexus files? Gabriel de Souza Fedel
Re: How do you generate nexus files? Matt Newville
Prev: Re: Keithley 2634B Source Meter Hartman, Steven M.
Next: Re: How do you generate nexus files? Gabriel de Souza Fedel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How do you generate nexus files? Gabriel de Souza Fedel
Next: Re: How do you generate nexus files? Mark Rivers
ANJ, 09 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
