1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Amptek IOC: Problem with subnet
From: Douglas Henrique C. de Araújo <[email protected]>
To: Hugo Slepicka <[email protected]>
Cc: [email protected]
Date: Wed, 16 May 2018 16:52:40 -0300
Hi Hugo,
Now I'm doing test in my local pc with IP 10.2.101.36 and the detector is connected in 10.2.103.31. in this case the ioc can't find the detector. We already configured the broadcast, but not has changed.
When I connect the detector in other port (10.2.101.34) the ioc works.
Another important point is that when we connected the detector in beamline network (subnet: 10.2.78.0) and we used the DppMCA Windows program (Running a windows pc on the subnet: 10.2.76.0), the DppMCA recognizes the detector.
Thank You
Regards
Em 16-05-2018 15:49, Hugo Slepicka escreveu:
Hi Douglas,
Can you provide more information about the IOC server network and also the detector network? (IP, Network Mask, Gateway, etc)...
Thank you,
Hugo
On Wed, May 16, 2018 at 10:51 AM Douglas Henrique C. de Araújo <[email protected]> wrote:
Hi, I'm using the amptek ioc from support mca7-7, and if the detector is
on the same network (and subnet) as the IOC server, it recognizes and
works perfectly. But if I change the detector subnet, the ioc can't find
the detector.
Does anyone knows if there is some configuration so that the amptek IOC
recognizes the detector that is connected in another subnet? Or has
anyone had a similar problem?
Thank you
Douglas Henrique C. de Araujo
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1228
www.lnls.br
www.lnls.br
Re: Amptek IOC: Problem with subnet Hugo Slepicka
Amptek IOC: Problem with subnet Douglas Henrique C . de Araújo
Prev: Re: Amptek IOC: Problem with subnet Hugo Slepicka
Next: Re: Amptek IOC: Problem with subnet Hugo Slepicka
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
