1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: msi "Could not open" error on Windows with file absolute path
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 22 May 2018 21:52:30 +0000
Hi Lewis,
Try using forward slashes instead of back-slashes, and also enclose the whole file path inside double quotes.
- Andrew
Sent from my iPad
> On May 22, 2018, at 5:46 PM, J. Lewis Muir <[email protected]> wrote:
> Hello, all.
> On Windows, when msi is used to expand a template substitution file that
> looks like:
> file C:\tmp2\dbExample1.db
> pattern { user }
>  { "luke" }
> it produces an error (the full output is at the end of this email):
> gmake[3]: Entering directory 'C:/tmp/myModuleApp/Db/O.win32-x86'
> echo "../O.Common/dbExampleMerge.db : " >> dbExampleMerge.db.d
> echo "dbExampleMerge.db.d: " >> dbExampleMerge.db.d
> "Inflating database from ../dbExampleMerge.substitutions "
> msi    -I. -I.. -I../O.Common -I../../../db -IC:/opt/epics-base/db -S../dbExampleMerge.substitutions  > dbExampleMerge.tmp
> Could not open C:\tmp2\dbExample1.db
> input:   which is
> gmake[3]: *** [C:/opt/epics-base/configure/RULES.Db:318: ../O.Common/dbExampleMerge.db] Error 1
> gmake[3]: Leaving directory 'C:/tmp/myModuleApp/Db/O.win32-x86'
> The problem seems to be related to the absolute pathname for the file
> directive in the template substitution file.  If I change it to a
> relative path (i.e., file ..\..\tmp2\dbExample1.db) it works.  However,
> I need to be able to use an absolute path.
> Does anyone know what's wrong and how to fix this?
> To reproduce this on Windows:
> C:\>call C:\opt\epics-base\startup\win32.bat
> C:\>mkdir tmp
> C:\tmp>cd tmp
> C:\tmp>makeBaseApp.pl -t example myModule
> C:\tmp>makeBaseApp.pl -i -t example myModule
> C:\tmp>cd ..
> C:\>mkdir tmp2
> C:\>copy tmp\myModuleApp\Db\dbExample1.db tmp2
> C:\>copy tmp\myModuleApp\Db\dbExample2.db tmp2
> Create the file C:\tmp\myModuleApp\Db\dbExampleMerge.substitutions:
> pattern { user }
>  { "luke" }
> file C:\tmp2\dbExample2.db
> pattern { user, no, scan }
>  { "han", "1", "5 second" }
> Add the following line, below the "DB += userHost.substitutions" line,
> to C:\tmp\myModuleApp\Db\Makefile:
> DB += dbExampleMerge.db
> Build:
> C:\>cd tmp
> C:\tmp>gmake
> Environment:
> * 32-bit Windows 7 Pro
> * Visual Studio C++ 2010 Express SP1
> * 32-bit Strawberry Perl 5.26.2.1
> * EPICS Base 3.14.12.7 + Known Problems patches
> * msi 1-7 + Andrew Johnson's patch from [1]
> * EPICS_HOST_ARCH=win32-x86
> Thank you!
> Lewis
> [1] https://epics.anl.gov/tech-talk/2015/msg01691.php
> C:\tmp>gmake
> gmake: Entering directory 'C:/tmp'
> gmake -C ./configure install
> gmake[1]: Entering directory 'C:/tmp/configure'
> perl C:/opt/epics-base/bin/win32-x86/makeMakefile.pl O.win32-x86 ../..
> perl -MExtUtils::Command -e mkpath O.Common
> gmake -C O.win32-x86 -f ../Makefile TOP=../.. \
>    T_A=win32-x86 install
> gmake[2]: Entering directory 'C:/tmp/configure/O.win32-x86'
> perl C:/opt/epics-base/bin/win32-x86/convertRelease.pl checkRelease
> gmake[2]: Leaving directory 'C:/tmp/configure/O.win32-x86'
> gmake[1]: Leaving directory 'C:/tmp/configure'
> gmake -C ./myModuleApp install
> gmake[1]: Entering directory 'C:/tmp/myModuleApp'
> gmake -C ./src install
> gmake[2]: Entering directory 'C:/tmp/myModuleApp/src'
> perl C:/opt/epics-base/bin/win32-x86/makeMakefile.pl O.win32-x86 ../../..
> gmake -C O.win32-x86 -f ../Makefile TOP=../../.. \
> gmake[3]: Entering directory 'C:/tmp/myModuleApp/src/O.win32-x86'
> perl C:/opt/epics-base/bin/win32-x86/makeIncludeDbd.pl base.dbd xxxSupport.dbd dbSubExample.dbd myModuleHello.dbd initTrace.dbd myModuleInclude.dbd
> echo "../O.Common/myModuleInclude.dbd : ../Makefile" >> myModule.dbd.d
> "Expanding dbd"
> "Installing dbd file ../../../dbd/xxxSupport.dbd"
> mkdir ../../../dbd
> "Installing created dbd file ../../../dbd/myModule.dbd"
> "Installing dbd file ../../../dbd/xxxRecord.dbd"
> echo "../O.Common/xxxRecord.h : ../Makefile" >> xxxRecord.h.d
> C:\\opt\\epics-base\\bin\\win32-x86\\dbToRecordtypeH.exe   -I. -I.. -I../O.Common -I../../../dbd -IC:/opt/epics-base/dbd ../xxxRecord.dbd xxxRecord.h
> "Installing generated generic include file ../../../include/xxxRecord.h"
> mkdir ../../../include
> cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\xxxRecord.c
> xxxRecord.c
> ..\xxxRecord.c(211) : warning C4244: '=' : conversion from 'epicsFloat64' to 'float', possible loss of data
> cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\devXxxSoft.c
> devXxxSoft.c
> cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\dbSubExample.c
> dbSubExample.c
> cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\myModuleHello.c
> myModuleHello.c
> cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\initTrace.c
> initTrace.c
> link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release       -implib:myModuleSupport.lib -out:myModuleSupport.dll         xxxRecord.obj devXxxSoft.obj dbSubExample.obj myModuleHello.obj initTrace.obj      C:\\opt\\epics-base\\lib\\win32-x86\\recIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\softDevIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\miscIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\rsrvIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbtoolsIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\asIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\registryIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbStaticIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\ca.lib  C:\\opt\\epics-base\\lib\\win32-x86\\Com.lib
>   Creating library myModuleSupport.lib and object myModuleSupport.exp
> Generating code
> Finished generating code
> "Installing shared library ../../../bin/win32-x86/myModuleSupport.dll"
> mkdir ../../../bin/win32-x86
> "Installing library ../../../lib/win32-x86/myModuleSupport.lib"
> mkdir ../../../lib/win32-x86
> perl C:/opt/epics-base/bin/win32-x86/registerRecordDeviceDriver.pl ../O.Common/myModule.dbd myModule_registerRecordDeviceDriver C:/tmp > myModule.tmp
> perl -MExtUtils::Command -e mv myModule.tmp myModule_registerRecordDeviceDriver.cpp
> cl -EHsc -GR -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD  -TP   -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        myModule_registerRecordDeviceDriver.cpp
> cl -EHsc -GR -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD  -TP   -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\myModuleMain.cpp
> myModuleMain.cpp
> link -nologo  -LTCG -incremental:no -opt:ref -release               -out:myModule.exe        myModule_registerRecordDeviceDriver.obj myModuleMain.obj     ..\\..\\..\\lib\\win32-x86\\myModuleSupport.lib  C:\\opt\\epics-base\\lib\\win32-x86\\recIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\softDevIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\miscIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\rsrvIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbtoolsIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\asIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\registryIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbStaticIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\ca.lib  C:\\opt\\epics-base\\lib\\win32-x86\\Com.lib
> Generating code
> "Installing created file ../../../bin/win32-x86/myModule.exe"
> gmake[3]: Leaving directory 'C:/tmp/myModuleApp/src/O.win32-x86'
> gmake[2]: Leaving directory 'C:/tmp/myModuleApp/src'
> gmake -C ./Db install
> gmake[2]: Entering directory 'C:/tmp/myModuleApp/Db'
> input:   which is
> gmake[2]: *** [C:/opt/epics-base/configure/RULES_ARCHS:61: install.win32-x86] Error 2
> gmake[2]: Leaving directory 'C:/tmp/myModuleApp/Db'
> gmake[1]: *** [C:/opt/epics-base/configure/RULES_DIRS:83: Db.install] Error 2
> gmake[1]: Leaving directory 'C:/tmp/myModuleApp'
> gmake: *** [C:/opt/epics-base/configure/RULES_DIRS:83: myModuleApp.install] Error 2
> gmake: Leaving directory 'C:/tmp'
Re: msi "Could not open" error on Windows with file absolute path J. Lewis Muir
Prev: RE: [UNTRUSTED] Problem accessing TextUpdate text property in Display Builder script. Gregory, Ray
Next: Re: Is it possible to make an IOC for an HTTP device? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: msi "Could not open" error on Windows with file absolute path J. Lewis Muir
Next: Re: msi "Could not open" error on Windows with file absolute path J. Lewis Muir
ANJ, 22 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
