1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Re: Installation of RTEMS and EPICS on MVME6100
To: <[email protected]>
Cc: 이충산 <[email protected]>, [email protected]
Date: Mon, 28 May 2018 09:19:32 +0900 (KST)
Could you tell me your configuration on server side(computer).
Especially, linux version, kernel verson and nfs Server version.
best regards.
------ Original Message ------
To: 유진성님([email protected])
Cc: [email protected], 이충산님([email protected])
Sent: 2018-05-27 00:43
Subject: Re: Installation of RTEMS and EPICS on MVME6100
I’m running RTEMS5 with EPICS7 booting looks like that ( use bootp)
(! Server name is [email protected]:/export/epics )
Copyright(C)2008-2009,Emerson Network Power-Embedded Computing,Inc.
All Rights Reserved
Copyright Motorola Inc. 1999-2007, All Rights Reserved
MOTLoad RTOS Version 2.0, PAL Version 2.3 RM01
Fri Jan 23 14:47:54 MST 2009
MPU-Type =MPC74x7
MPU-Int Clock Speed =1266MHz
MPU-Ext Clock Speed =133MHz
MPU-Int Cache(L2) Enabled, 512KB, L2CR =C0000000
MPU-Ext Cache(L3) Enabled, 2MB, 211MHz, L3CR =DC026000
PCI bus instance 0 =64 bit, 133 Mhz, PCI-X
PCI bus instance 1 =64 bit, PCI
Reset/Boot Vector =Flash1
Local Memory Found =20000000 (&536870912)
User Download Buffer =006B7000:008B6FFF
MVME6100> tftpGet -c141.14.128.53 -s141.14.133.59 -m255.255.240.0 -a04000000 -fcry-test.boot
Network Loading from: /dev/enet0
Loading File: cry-test.boot
Load Address: 04000000
Download Buffer Size = User Defined
Client IP Address = 141.14.128.53
Server IP Address = 141.14.133.59
Gateway IP Address = 141.14.128.253
Subnet IP Address Mask = 255.255.240.0
Network File Load in Progress...
Bytes Received =&4914608, Bytes Loaded =&4914608
Bytes/Second =&2457304, Elapsed Time =2 Second(s)
MVME6100> waitProbe
System I/O Probe Complete
MVME6100> netShut
/dev/enet0 -----------------------------------------
config addr is 0xf1000cf8
config data is 0xf1000cfc
Welcome to RTEMS rtems-5.0.0 (PowerPC/Generic (classic FPU)/beatnik)
CPU: MPC7457
Board Type: MVME6100-0163 (S/N E11A4B3)
Bus Clock Freq: 133333333 Hz
CPU Clock Freq: 1266666654 Hz
Memory: 536870912 bytes
Now BSP_mem_size = 0x1fe00000
Configuration.work_space_size = 2304980
Page table setup finished; will activate it NOW...
Going to start PCI buses scanning and initialization
Number of PCI buses found is : 3
MSR 0x2003032
Exit from bspstart
unable to find the universe in pci config space
Tundra Tsi148 PCI-VME bridge detected at 0x81100000, IRQ 84
Tsi148 Outbound Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0e000000 0x90000000 A32, SUP, D32, SCT
1: 0x00000000 0x00ff0000 0x9f000000 A24, SUP, D32, SCT
2: 0x00000000 0x00010000 0x9fff0000 A16, SUP, D32, SCT
7: 0x00000000 0x01000000 0x9e000000 CSR, SUP, D32, SCT
Tsi148 Inbound Ports:
0: 0x90000000 0x1fe00000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
vmeTsi148 - IRQ manager using VME CSR to flush FIFO
Registering /dev/console as minor 0 (==/dev/ttyS0)
BSP doesn't implement non-volatile memory.
***** RTEMS Version: rtems-5.0.0 (PowerPC/Generic (classic FPU)/beatnik) *****
Startup.
***** Initializing network *****
Link detected; attaching mve1
bootpc_init: using network interface 'mve1'
bootpc hw address is ec:9e:cd:10:18:82
My ip address is 141 .14 .128 .12
Domain Name Server is 141 .14 .128 .1
Hostname is gonzo
Ignoring BOOTP/DHCP option code 28
Time Server is 141 .14 .142 .121
Domain name is rz-berlin.mpg.de
Boot file is /export/epics/cry-test/bin/RTEMS-beatnik/cry-test
Command line is /export/epics/cry-test/iocBoot/ioccry-test/st.cmd
Subnet mask is 255 .255 .240 .0
Server ip address is 141 .14 .128 .1
Gateway ip address is 141 .14 .128 .128
Log server ip address is 141 .14 .128 .1
***** Setting up file system *****
bootFileName: /export/epics/cry-test/bin/RTEMS-beatnik/cry-test
***** Initializing TFTP *****
***** Initializing NFS *****
RTEMS-RPCIOD, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
RTEMS-NFS, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
nfsMount("[email protected]", "/export/epics", "/export/epics") -> 0
************ INTERFACE STATISTICS ************
***** lo0 *****
Address:127.0.0.1 Net mask:255.0.0.0
Flags: Up Loopback Running Multicast
Send queue limit:50 length:0 Dropped:0
***** mve1 *****
Ethernet Address: EC:9E:CD:10:18:82
Address:141.14.128.12 Broadcast Address:141.14.143.255 Net mask:255.255.240.0
Heinz
Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
Faradayweg 4-6 |
D - 14195 Berlin | E-Mail: [email protected]
> On 25. May 2018, at 09:03, 유진성 <[email protected]> wrote:
> I have some questions about configuration of MVME6100.
> My purpose is to run EPICS IOC on VME-EVR-230, VME-EVG-230 and MVME6100.
> When I try to download RTEMS boot file from server to MVME6100, there is an error message for 'nfsMount' on MVME6100 side.
> (I got these messages via Debug port on MVME6100), And then nfs client didn't mount to nfs server.
> I don't know what problem is.
> Is anyone check my log and environments what trouble is?
> my log and environments are below:
> ==hardware==
> 1) MVME6100
> 2) VME-EVR-230
> 3) VME-EVG-230
> ==software===
> 1) Scientific Linux 6.5 (server)
> 2) EPICS: R3.14.12 (server)
> 3) RTEMS: 4.10.2 (server)
> 4) BSP: beatnik (server)
> 1. boot log on MVME6100
> ========== boot log on MVME6100 ==========
> All Rights Reserved
> MPU-Type =MPC74x7
> MPU-Ext Cache(L3) Enabled, 2MB, 211MHz, L3CR =DC026300
> Local Memory Found =80000000 (&2147483648)
> MVME6100> tftpget -s192.168.2.229 -c192.168.2.240 -fepics/demo/bin/RTEMS-beatnik/test.boot
> Loading File: epics/demo/bin/RTEMS-beatnik/test.boot
> Load Address: 006B7000
> Download Buffer Size = 00200000
> Client IP Address = 192.168.2.240
> Server IP Address = 192.168.2.229
> Gateway IP Address = 192.168.0.1
> Subnet IP Address Mask = 255.255.252.0
> Bytes Received =&1706484, Bytes Loaded =&1706484
> Bytes/Second =&1706484, Elapsed Time =1 Second(s)
> MVME6100>-----------------------------------------
> config addr is 0xF1000CF8
> config data is 0xF1000CFC
> Welcome to RTEMS rtems-4.10.2(PowerPC/Generic (classic FPU)/beatnik)
> CPU: MPC7457
> Board Type: MVME6100-2173 (S/N E183652)
> Memory: 2147483648 bytes
> Now BSP_mem_size = 0x7F800000
> Configuration.work_space_size = A4D10
> MSR 2003032
> Exit from bspstart
> Tsi148 Inbound Port Cfg: invalid address/length; must be < 1<<32
> 0: 0x20000000 0x0E000000 0x90000000 A32, SUP, D32, SCT
> 1: 0x00000000 0x00FF0000 0x9F000000 A24, SUP, D32, SCT
> 2: 0x00000000 0x00010000 0x9FFF0000 A16, SUP, D32, SCT
> 7: 0x00000000 0x01000000 0x9E000000 CSR, SUP, D32, SCT
> Startup.
> Mount 192.168.2.229:/usr/local/epics on /usr/local/epics
> RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
> RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
> RPCIO: server '192.168.2.229' not responding - still trying
> Unable to contact NFS server - invalid port? (RPC: Timed out)
> mount failed: Unknown protocol
> rtems_bsdnet_get_ntp() Can't send: Host is down
> ***** Starting EPICS application *****
> Can't open /home: No such file or directory
> 2.gevshow commend on MOTload
> ============= gev show =============
> MVME6100> gevshow
> mot-/dev/enet0-cipa=192.168.2.240
> mot-/dev/enet0-sipa=192.168.2.229
> mot-/dev/enet0-snma=255.255.252.0
> rtems-client-name=BNCT_TIMING
> epics-script=/home
> mot-/dev/enet0-gipa=192.168.0.1
> mot-script-boot
> netShut
> go
> rtems-dns-server=1.1.1.1
> mot-/dev/enet0-file=epics/demo/bin/RTEMS-beatnik/test.boot
> epics-nfsmount=192.168.2.229:/usr/local/epics:/usr/local/epics
> Total Number of GE Variables =10, Bytes Utilized =439, Bytes Free =3153
> 3. Information on nfs server side
> [root@localhost local]# rpcinfo -p 192.168.2.229
> program vers proto port service
> 100000 4 tcp 111 portmapper
> 100000 3 tcp 111 portmapper
> 100000 2 tcp 111 portmapper
> 100000 4 udp 111 portmapper
> 100000 3 udp 111 portmapper
> 100000 2 udp 111 portmapper
> 100011 1 udp 875 rquotad
> 100011 2 udp 875 rquotad
> 100011 1 tcp 875 rquotad
> 100011 2 tcp 875 rquotad
> 100005 1 udp 34798 mountd
> 100005 1 tcp 40401 mountd
> 100005 2 udp 53440 mountd
> 100005 2 tcp 54014 mountd
> 100005 3 udp 35346 mountd
> 100005 3 tcp 49462 mountd
> 100003 2 tcp 2049 nfs
> 100003 3 tcp 2049 nfs
> 100003 4 tcp 2049 nfs
> 100227 2 tcp 2049 nfs_acl
> 100227 3 tcp 2049 nfs_acl
> 100003 2 udp 2049 nfs
> 100003 3 udp 2049 nfs
> 100003 4 udp 2049 nfs
> 100227 2 udp 2049 nfs_acl
> 100227 3 udp 2049 nfs_acl
> 100021 1 udp 42432 nlockmgr
> 100021 3 udp 42432 nlockmgr
> 100021 4 udp 42432 nlockmgr
> 100021 1 tcp 4001 nlockmgr
> 100021 3 tcp 4001 nlockmgr
> 100021 4 tcp 4001 nlockmgr
> [root@localhost local]# ifconfig
> p3p1 Link encap:Ethernet HWaddr B4:96:91:04:2A:DD
> inet addr:192.168.2.229 Bcast:192.168.3.255 Mask:255.255.252.0
> inet6 addr: fe80::b696:91ff:fe04:2add/64 Scope:Link
> UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
> RX packets:3416123 errors:0 dropped:0 overruns:0 frame:0
> TX packets:784304 errors:0 dropped:0 overruns:0 carrier:0
> collisions:0 txqueuelen:1000
> RX bytes:396950516 (378.5 MiB) TX bytes:462271580 (440.8 MiB)
> Memory:f7600000-f7700000
> [root@localhost local]# vi /etc/exports
> /usr/local/epics *(ro,all_squash,no_subtree_check,async)
> /usr/local/eldk/eldk/ppc_74xx *(rw,sync,no_root_squash,secure)
> /tftpboot/epics *(ro,sync)
> [root@localhost local]# vi /etc/sysconfig/nfs
> # Define which protocol versions mountd
> # will advertise. The values are "no" or "yes"
> # with yes being the default
> MOUNTD_NFS_V2="yes"
> #MOUNTD_NFS_V3="yes"
> [root@localhost local]# uname -a
> Linux localhost.localdomain 2.6.32-431.el6.i686 #1 SMP Thu Nov 21 13:48:12 CST 2013 i686 i686 i386 GNU/Linux
Prev: Re: EtherCAT newbie question Jeong Han Lee
Next: A recent R3.15.5 Patch file Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installation of RTEMS and EPICS on MVME6100 Heinz Junkes
Next: VME configuration : MVME6100 can not map slot x to CR/CSR 유진성
ANJ, 28 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
