1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Parsing problem with stream
To: <[email protected]>
Date: Tue, 5 Jun 2018 11:28:44 +0200
For fixed-length input you can use maxInput=number_of_byes; instead of a
terminator.
   I tried bracketing my read of 'ACK' with 'MaxInput=1' and 'MaxInput=0',
but it didn't help - still nothing in my PV.
At them moment, you cannot change variables at run-time. The protocol starts and runs with the last setting. Thus this:
MaxInput=1;
in ACK;
MaxInput=0;
in "...";
Actually executes:
MaxInput=0;
in ACK;
in "...";
This is because setting variable like MaxInput is evaluated when the protocol is loaded, not at run-time like the 'in' command. I plan to change that in the future.
Wahat I meant was:
read_version {
      MaxInput=...;
      out STX, "001?f" ETX, "%<xor8ff>";
      in ACK, STX, "001 f%[^\003]", ETX, "%1<xor8ff>";
Read everything including ACK as one fixed length line.
In cases you have no terminator string but constant length input, using MaxInput saves you from using readTimeout as the line terminator. Thus you have no delay at the end of the input and no danger that two lines join to one in case readTimeout is too long.
Dirk
Re: Parsing problem with stream Lucock, Richard M
Re: Parsing problem with stream Dirk Zimoch
Prev: Re: Parsing problem with stream Lucock, Richard M
Next: Re: Parsing problem with stream Lucock, Richard M
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 05 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
