1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Ethernet attached stepper motors
To: [email protected]
Date: Fri, 15 Jun 2018 09:44:53 +0200
we tested the usage of a Schneider mDrive hybrid stepper motor, which has an ethernet port integrated and can be controlled via modbus, ethernet ip or with streamdevice.
https://imshome.com/downloads/manuals/MDrive_Hybrid_EtherNet-IP.pdf
If you are interested I have an ioc to control it via streamdevice, even though it's not using the motor record.
Davide
On 14/06/2018 20:09, Pearson, Matthew R. wrote:
There is some interest at the SNS in using ethernet attached stepper motors for easy integration with modular ad-hoc motion projects. For example:
https://www.arcus-technology.com/products/integrated-stepper-motors/nema-23-integrated-ethernet-stepper-2/
https://www.omega.com/pptst/STM_SERIES.html
I found this brief tech-talk chain:
https://epics.anl.gov/tech-talk/2015/msg00736.php
I am wondering if anyone is using these and has any recommendations?
The Arcus drives seem easy to use (ASCII command set over TCP/IP). Although they have a very complex factory reset procedure. There’s seems to be an EPICS driver for one of the Arcus multi-axis controllers.
The advantages of these would seem to be lower cost and fewer cables. Although to wire in limits switches would still need cabling work, and there’s still an external power supply required.
The main disadvantage is that it’s a new unknown controller type, and we already use several other controllers that can drive stepper motors. Instead, I am wondering if it’s worth fabricating a portable single axis box out of our standard motion controller (which for this case would be a single axis Galil controller).
Cheers,
Matt
Data Acquisition and Controls Engineer
Spallation Neutron Source
Oak Ridge National Lab
Davide Marcato
INFN - Laboratori Nazionali di Legnaro
Viale dell'Universita', 2
35020 LEGNARO (PD) - ITALY
Phone: +39 0498068439
Ethernet attached stepper motors Pearson, Matthew R.
Prev: time series circular buffer Hinko Kocevar
Next: RE: time series circular buffer [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Ethernet attached stepper motors Pearson, Matthew R.
Next: time series circular buffer Hinko Kocevar
ANJ, 15 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
