1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: time series circular buffer
To: 'Hinko Kocevar' <[email protected]>, "[email protected]" <[email protected]>, Tech-talk <[email protected]>
Date: Fri, 15 Jun 2018 23:07:06 +0000
Hi Hinko,
I think it would be useful to be able to run the time series in circular buffer mode.  There are 2 ways this might be done:
- Add the code for circular buffer mode to the statistics plugin
- Move the time series code out of the statistics plugin and have the statistics plugin send the time points as NDArrays to time series plugins.
I'm not sure which is best.
I have created an issue for this in ADCore.
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of Hinko Kocevar
Sent: Friday, June 15, 2018 3:55 AM
To: [email protected]; Tech-talk <[email protected]>
Subject: Re: time series circular buffer
Hi Tom,
thanks for the suggestion, I have not used this particular plugin so far. I'll give it a try!
Cheers,
Hinko
Sent: Friday, June 15, 2018 9:44:57 AM
To: Hinko Kocevar; Tech-talk
There is the NDPluginAttrPlot plugin which takes any numeric stamped NDAttributes (like the ones the NDPluginStats produces) and puts them in a circular buffer, periodically pushing the last N samples to a set of waveforms. We use it to plot arbitrary attributes against each other.
http://cars9.uchicago.edu/software/epics/NDPluginAttrPlot.html
Tom
> Sent: 15 June 2018 07:38
> To: Tech-talk <[email protected]>
> Subject: time series circular buffer
> Hi,
> in areaDetector NDPluginStats plugin I can get nice timeseries plots
> for max, mean, min.
> After the number of predefined points are collected the storing stops.
> Is there a way to configure timeseries buffer as a circular buffer?
> I've noticed that NDTimeSeries has this feature, but I'm failing to
> find one in NDPluginStats.
> Thanks,
> Hinko Kocevar
> Beam Diagnostics Engineer
> European Spallation Source ERIC
> P.O Box 176, SE-221 00 Lund, Sweden
> Visiting address: Odarslövsvägen 113, SE-224 84 Lund , Sweden
> Mobile: +46-721-79 22 58
> Phone:  +46-46-888 32 58
> E-mail: [email protected]
> Web:    www.esss.se
RE: time series circular buffer Hinko Kocevar
RE: time series circular buffer [email protected]
Re: time series circular buffer Hinko Kocevar
Prev: Re: Problem accessing repository of sequencer Benjamin Franksen
Next: Download link for June 2018 EPICS Talks Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: time series circular buffer Hinko Kocevar
Next: RE: time series circular buffer Hinko Kocevar
ANJ, 19 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
