Hello tech-talkers,
I am trying to install MEDM on CentOS for the first time but I get an error on the process. I have downloaded the tar file corresponding to the version 3.1.11 and unzipped it in the EPICS/extensions/src directory. Then
I do make from the extensions directory and get the following error:
usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -Wextra -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux
-I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include -I../../../../include -I -MM -MF xwd2ps.d ../xwd2ps.c
cc1: error: to generate dependencies you must specify either -M or -MM
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -Wextra -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux
-I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include -I../../../../include -I -MM -MF xwd.d ../xwd.c
-I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include -I../../../../include -I -MM -MF utilPrint.d ../utilPrint.c
-I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include -I../../../../include -I -MM -MF ps_utils.d ../ps_utils.c
-I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include -I../../../../include -I -MM -MF pUtils.d ../pUtils.c
-I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include -I../../../../include -I -MM -MF getopt.d ../getopt.c
-I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include -I../../../../include -I -c ../getopt.c
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
collect2: error: ld returned 1 exit status
Am I missing any step in the installation process? I haven’t find any installation manual so it is possible I am missing something obvious.
Ignacio Casal Iglesias
Desarrollador de software/ Software developer
GMV
Isaac Newton, 11
P.T.M. Tres Cantos
E-28760 Madrid
Tel. +34 91 807 33 29
Fax +34 91 807 21 99
www.gmv.com
