1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AreaDetector ADPICam driver question
To: [email protected]
Date: Thu, 21 Jun 2018 13:50:49 +0200
Hi Mark,
meanwhile I managed to get it working somehow. I Have to unplug the camera
sometimes after start of the IOC because it gets a message from
PicamAdvanced_DiscoverCameras() that the camera was lost. But besides that
everything seems to work, at least with PICam library version 5.2.1. The newer
version (5.3.3) does not work. It fails to open the camera! I'm in contact
with Princeton Instruments about this issue. It must be some access right not
being set properly for a device file on my system. By The way, I noticed some
minor mistakes in the driver(Missing parameters, asynPrint parameters missing,
wrong error message etc.). I will send in a patch once the code has proven to
work.
Jörn
Am Donnerstag, 21. Juni 2018, 13:23:40 CEST schrieb Mark Rivers:
> Hi Jörn,
> I don't know anyone using PICam on Linux with areaDetector, but hopefully
> someone is, and can help you.
> If you get stuck then I do have a lot of experience controlling PIXIS
> cameras with areaDetector using the ADLightField driver on Windows.  That
> is working reliably for us.
> Mark
> ________________________________
> From: [email protected] <[email protected]> on
> behalf of Jörn Dreyer <[email protected]> Sent: Thursday, June 21, 2018 1:46
> AM
> Subject: AreaDetector ADPICam driver question
> Hello,
> I'm currently in the process of setting up the areaDetector driver for a
> PrincetonInstruments PIXIS detector using Linux.
> I have downloaded the latest PICam SDK from Princetons FTP server. But
> Failed to get it working.
> Has anybody done that before? Which version was used under Windows for the
> development?
> I have tested version 5.2.1 and 5.3.3. The older version reports
> Camera Lost: PIXIS-XF: 2048B - device 0x0
> While the newer one fails already at opening of the camera with
> "Unknow error"!
> Regards,
> Jörn
AreaDetector ADPICam driver question Jörn Dreyer
Re: AreaDetector ADPICam driver question Mark Rivers
Prev: Re: AreaDetector ADPICam driver question Mark Rivers
Next: Inconsistent EPICS Base 3.14 startup files J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 21 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
