Subject: |
Why do EPICS Base startup scripts refer to non-depedencies? |
"J. Lewis Muir" <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Fri, 22 Jun 2018 10:50:40 -0500 |
Hello, EPICS Base developers!
Why do the scripts in the EPICS Base 3.14, 3.15, and 3.16 startup
directory refer to things that are not dependencies of EPICS
Base (e.g., EPICS_EXTENSIONS, PSPRINTER for some extensions,
EPICS_DISPLAY_PATH and BROWSER for MEDM, ADTHOME for ADT, Exceed X11,
etc.)?
IMO, the startup scripts should only refer to things related to EPICS
Base. For example, EPICS Base doesn't know anything about MEDM nor
should it. Therefore, <EPICS Base>/startup/Site.profile should not
set EPICS_DISPLAY_PATH or anything else that relates to MEDM. A much
better way would be for the EPICS Extensions package (currently known
as "Extensions build configure files") to provide a Site.profile, for
example, that can be edited to provide the environment or shell changes
required by the different extensions. Since MEDM, for example, is
an extension, then EPICS_DISPLAY_PATH and BROWSER should be set in
the Site.profile provided with the EPICS Extensions package, not the
Site.profile in EPICS Base.
Lewis
- Re: Why do EPICS Base startup scripts refer to non-depedencies? Andrew Johnson
Re: Inconsistent EPICS Base 3.14 startup files J. Lewis Muir
<2018>
2025
2026
<2018>
2025
2026
