1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 'assert (pca->pgetNative)' failed in ../dbCa.c
To: 'Andrew Johnson' <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 29 Jun 2018 06:43:40 +0000
> So by this point you're probably hoping that the attached patch fixes
> the issue; well congratulations for reading this far, I tried out my
> suspicion above and the attached patch does seem to work for me on the
> 3.14 branch version, which should be close enough to yours to be able to
> apply one way or the other. Please test and let me know so I can apply
> it to the Base-3.14 branch and merge up.
I've just noticed that the patch doesn't address the data type mismatch directly, only through the separate connection callback.  Is this going to be enough to avoid hitting those asserts even in the presence of an IOC server breaking the rules?
After all, an assert is a confident statement that the invariant in question is never going to be broken, because all of the elements of the invariant are under *our* control; but in this case aren't we still in the situation where the ca_field_type() is not as expected?  Or are you saying (implicitly) that here connectionCallback() is *guaranteed* to be called before any change of ca_field_type()?
I have a feeling that in our case when we saw the failure, it wasn't so much that the restarting server changed its record type, but that there was something rather more bumpy about its restart (my colleague working on it was trying to migrate between different EPICS and Linux versions with some unexpected failures).  However the only concrete evidence we have is the error message and a large coincidence.
Re: 'assert (pca->pgetNative)' failed in ../dbCa.c Andrew Johnson
'assert (pca->pgetNative)' failed in ../dbCa.c [email protected]
Prev: RE: 'assert (pca->pgetNative)' failed in ../dbCa.c [email protected]
Next: Re: 'assert (pca->pgetNative)' failed in ../dbCa.c Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 29 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
