1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: New releases of areaDetector drivers ADAndor, ADPixirad, ADPointGrey, ADSimDetector
Date: Mon, 2 Jul 2018 17:22:14 +0000
Folks,
New releases of the following areaDetector modules are now available.
ADAndor
R2-8 (July 1, 2018)
* Added support for new PVs in ADCore R3-3 in opi files (NumQueuedArrays, EmptyFreeList, etc.)
* Changed configure/RELEASE files for compatibility with areaDetector R3-3.
* Improved op/*/autoconvert/* files with better medm files and better converters.
ADPixirad
R2-2 (July 2, 2018)
* Added support for the PIXI-III chip
  - New CountMode record to select Normal, NPI and NPISUM count modes.
  - New HitThreshold record to control the VtHit value.
  - Added new pixiradAutoCal iocsh command to set the 7 calibration values unique to each PIII detector.
* Changed AUTOCAL so that it does not read back the calibration images.
  These were not useful, added complexity, and could be confusing to the user.
ADPointGrey
R2-7 (2-July-2018)
* Fixed camera timestamps to use EPICS epoch, not Posix epoch.
* Fixed problem with libflycapture.so in Makefile on Linux.
ADSimDetector
R2-8 (July 1, 2018)
* Changed Makefile to use addprefix to add -I to user-defined include file directory paths
* Fixed so it builds OK if WITH_HDF5=NO.
* Changed simDetector.adl to have the new records from ADCore R3-3.
* Updated the edl, ui, and opi autoconvert directories to contain the conversions
  from the most recent adl files and improved converters.
* Fixed comments in the files in the iocBoot directories.  Thanks to Lewis Muir for this.
Prev: areaDetector R3-3-1 released Mark Rivers
Next: Re: Setting items property for Combo widget in Display Builder Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: New releases of areaDetector drivers: ADDexela, ADLightField, ADPerkinElmer, ADPilatus, ADmarCCD, pvaDriver Mark Rivers
ANJ, 02 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
