1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: measComp R2-1 released
Date: Mon, 2 Jul 2018 21:10:35 +0000
Folks,
Release 2-1 of the measComp module is now available.
This is from the release notes:
* Changed from using std::thread and std::mutex to using epicsThread, epicsMutex, and epicsEvent from the EPICS libCom library.
  This allows it to build on older compilers, and is easier to understand.
* Fixed problem with uninitialized variables in E-TC and E-TC32 drivers on Linux. This could lead to failures to connect to the devices at iocInit.
* Rearranged code directories.
  * Split linuxSrc into cbw_linuxSrc (which contains the cbw library emulation for Linux) and LinuxDrivers (which contains Warren Jasper's Linux drivers).
  * Moved cbw.h, cbw32.lib, and cbw64.lib from src/ into new directory measCompSupport.
The home page for measComp is here:
http://cars.uchicago.edu/software/epics/measComp.html
The documentation is here:
http://cars.uchicago.edu/software/epics/measCompDoc.html
The release notes are here:
http://cars.uchicago.edu/software/epics/measCompReleaseNotes.html
The source repository is on Github:
https://github.com/epics-modules/measComp
Cheers,
Prev: dxp R5-0 available Mark Rivers
Next: Modbus R2-11 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 02 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
