1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building latest AreaDetector from the synApps collection
To: "Abdalla Ahmad" <[email protected]>, "Rivers, Mark L." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 5 Jul 2018 14:42:01 +0000
The dxpSITORO issue is due to the script referring to a previous tagged version of the support directory. The makefile in support has been updated since then, but the script doesn't yet grab it, I'll fix that. The areaDetector issue comes from "make release" not searching and replacing RELEASE_BASE.local and RELEASE_SUPPORT.local, will fix that as well.
From: [email protected] <[email protected]> on behalf of Abdalla Ahmad <[email protected]>
Sent: Thursday, July 5, 2018 1:12:44 AM
To: Rivers, Mark L.; [email protected]
Subject: RE: Building latest AreaDetector from the synApps collection
Hello Mark
Fortunately few minutes later I managed to build the entire package successfully. What I did is that I ran "assembly_synapps.sh" in a different folder than the target one, then I moved the whole package to the target folder and modifying configure/RELEASE for correct definitions. I think this made the conflict because later I ran "assembly_synapps.sh" inside the target folder and the build process completed successfully.
One more thing is that module dxpSITORO-R1-0 was unable to build due to incorrect dependencies location. I opened the configure/RELEASE file inside it, modified the definitions and the build works successfully. Attached is the modified RELEASE file for this module.
Thank you very much.
Abdalla.
Sent: Wednesday, July 04, 2018 4:45 PM
To: Abdalla Ahmad <[email protected]>; [email protected]
Hi Abdalla,
Please send the complete output of the command that generated that error.  It looks like it is not looking in asyn for include files, but I want to see the exact command.
From: [email protected] <[email protected]> On Behalf Of Abdalla Ahmad
Sent: Wednesday, July 4, 2018 5:35 AM
To: [email protected]
Subject: Building latest AreaDetector from the synApps collection
Hi
I cloned this repo https://github.com/EPICS-synApps/support and ran assembly_synapps.sh , all components are cloned successfully. In the main configure/RELEASE file I modified the support and base locations, then I ran "make release" then "make" and it started fine until It started building area detector I think where I got multiple errors but all of them saying:
../asynNDArrayDriver.h:4:28: fatal error: asynPortDriver.h: No such file or directory.
#include "asynPortDriver.h"
At the main configure/RELEASE nothing is commented, all modules are included in the build. Am I missing some other configuration?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Building latest AreaDetector from the synApps collection Abdalla Ahmad
RE: Building latest AreaDetector from the synApps collection Mark Rivers
RE: Building latest AreaDetector from the synApps collection Abdalla Ahmad
Prev: Re: ADLambda compilaiton of vendor sources (LambdaSupport) Mark Rivers
Next: Is EPICS license GPL-compatible? Gabriel de Souza Fedel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Building latest AreaDetector from the synApps collection Abdalla Ahmad
Next: ADLambda compilaiton of vendor sources (LambdaSupport) Gofron, Kazimierz
ANJ, 06 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
