1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Subject: Re: Delta Tau Power Brick LV-IMS driver
To: Mark Davis <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 6 Jul 2018 20:02:11 +0200
The problem is the PROBLEM bit, as far as I can see.
Which exact version of the motorRecord are you using ?
The code on latest master looks like this:
    /* Get motor-now-moving indicator. */
    if (ls_active == true || msta.Bits.RA_DONE || msta.Bits.RA_PROBLEM)
        pmr->movn = 0;
        if (ls_active == true || msta.Bits.RA_PROBLEM)
            clear_buttons(pmr);
            if (msta.Bits.RA_PROBLEM)
                pmr->stop = 1;
                MARK(M_STOP);
    else
        pmr->movn = 1;
And this was changed here:
commit 303a9208e368ef07839afff67bac69e429af7332
Author: Ron Sluiter <[email protected]>
Date:   Fri May 23 15:39:57 2014 +0000
    - Set "stop" field true if driver returns RA_PROBLEM true.
    - Increment version to 6.9
So my suggestion would be to
a) revert that commit in your motor code base
  (git revert 303a9208e368ef07839afff67bac69e429af7332)
b) Remove the line in the model 3 driver that sets the PROBLEM bit
HTH
/Torsten
On 06/07/18 17:13, Mark Davis wrote:
Working with some new equipment here and having some problems getting things working correctly and hoping someone can give me some tips on what to look for.
We have a couple of new Delta Tau Power Brick LV-IMS controllers that I need to get working ASAP.
Here is where I am at the moment:
    - I have an EPICS 3.14.12.2 IOC running the following:
       - The powerPMAC driver from http://www.observatorysciences.co.uk/deltatau_downloads.php,
        - The ssh2 library as described in the manual for the driver
        - Version 6-9 of the motor module
        - Version 4-23 of the asyn module
       - The records included in the example/test IOC config included with the driver (which includes a motor record)    - The latest PowerMAC IDE application from Delta Tau running on a Windows 7 computer    - A FESTO stepper motor (Model EMMS-ST-57-S-SEB-G2), which includes a brake and an encoder    - The appropriate power supply from Delta Tau to provide the power for the controller and (through it) the motor    - A very basic configuration/program running on the Delta Tau (one which I was told is basically a copy of one of the examples provided by Delta Tau) which includes definitions for 8 open-loop axes (where the reported position is based on the # of steps) and 8 read-only virtual axes that report the position based on the encoder counts.
Both the IOC and the IDE application can connect to the Delta Tau, and I can open a command-line shell to it via SSH (the controller runs some version of Linux)
If the IOC is not running, when I use the IDE application to jog the motor it will move until it reaches the the specified position.
When the IOC is running, if I change the setpoint for the motor record, the motor moves a bit in the correct direction but quickly stops.  This is presumably because the PROBLEM bit in the motor record's MSTA field is always set so the motor record is in the major STATE alarm state, causing the record logic to stop the motor movement.
The brief description of the PROBLEM bit simply says "driver stopped polling, or hardware problem".  But fields in the motor record are frequently updating, showing any changes in the position of the motor, so I wouldn't think it would be a polling problem.  And the fact that everything appears to work fine when using the IDE application would seem to imply that there are no hardware problems.
I will be digging through the code trying to trace this back to some identifiable cause, but if anyone has any experience with this controller and has some tips on what I might check or should be looking for, that would be much appreciated.
Mark Davis
NSCL/FRIB
    - The ssh2 library
I have this driver installed on a Linux box running EPICS 3.14.12.2 and (as explained in the doco for this driver) installed the libssh2 library it needs to open an SSH connection to the controller.
I know almost nothing about the controller itself, but was provided with a very basic "project" with some code that I was told is mostly a copy of some example from Delta Tau.
I have
Delta Tau Power Brick LV-IMS driver Mark Davis
Prev: RE: Delta Tau Power Brick LV-IMS driver Mark Rivers
Next: Re: Delta Tau Power Brick LV-IMS driver Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Prev: Re: Delta Tau Power Brick LV-IMS driver Mark Davis
ANJ, 20 Jul 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
