1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Missing libtiff4 in installing NSLS-II EPICS packages on Ubuntu Trusty
To: EPICS Tech Talk <[email protected]>
Date: Tue, 3 Jul 2018 19:32:20 +0000
I am attempting to install EPICS from the NSLS-II packages at https://epics.nsls2.bnl.gov/debian/, specifically using the wheezy repo.  When I try to install the package epics-areadetector, I get the following error:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
epics-areadetector : Depends: libareadetector1.9 but it is not going to be installed
                      Depends: libtiff4 (> 3.9.5-3~) but it is not installable
                      Recommends: edm-areadetector (= 1.9.1+dfsg1-1) but it is not going to be installed
                      Recommends: libareadetector1.9 (= 1.9.1+dfsg1-1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
When I look in aptitude, I can install libtiff4-dev, but the package description seems to indicate that libtiff4 is deprecated.
What steps can I take to install EPICS on this computer?
Thank you,
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 | www.SydorTechnologies.com
Skype: [email protected]
Prev: Re: RTEMS NFS/RPIOC problems? Ricardo Cardenes
Next: RE: RTEMS NFS/RPIOC problems? Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: RTEMS NFS/RPIOC problems? Hill, Jeff
Next: Missing libtiff4 in installing NSLS-II EPICS packages on Ubuntu Trusty Iain Marcuson
ANJ, 18 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
