1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Rotating Image in NDPluginPva plugin
To: "J. Lewis Muir" <[email protected]>, "Shen, Guobao" <[email protected]>
Cc: Tech-Talk <[email protected]>
Date: Wed, 18 Jul 2018 15:35:03 +0000
Hi Guobao,
Lewis is correct.  The NDPluginPva has never had rotation capability, you should use the NDPluginTransform for that.
From: [email protected] <[email protected]> on behalf of J. Lewis Muir <[email protected]>
Sent: Wednesday, July 18, 2018 10:18 AM
To: Shen, Guobao
Cc: Tech-Talk
On 07/18, Shen, Guobao wrote:
> Hi,
> I found there was an old discussion to rotate image by 90 degree (or 270 degree) in areaDetector NDPluginPva plugin,
> https://epics.anl.gov/tech-talk/2017/msg00454.php
> Is that function available to use now?
> Thanks,
> Guobao
Can't you use NDPluginTransform to rotate, and then feed that to
NDPluginPva?
Lewis
Re: Rotating Image in NDPluginPva plugin Shen, Guobao
Re: Rotating Image in NDPluginPva plugin J. Lewis Muir
Prev: Re: Rotating Image in NDPluginPva plugin J. Lewis Muir
Next: Re: MEDM compilation on Ubuntu 16.04 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Rotating Image in NDPluginPva plugin Shen, Guobao
ANJ, 18 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
