1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Motor record question
To: [email protected]
Date: Mon, 23 Jul 2018 15:50:15 +0200
Hello,
I'm currently developing a driver for a in house build MotorControler based on
a microcontroller. This can be accessed via ethernet using a dedicate
protocol. The controller is housed in a 19" rack together with up to six
driver cards each capable of driving 6 motors. Some of the driver cards can be
replaced by encoder input cards. To make the system even more complex, there
are two types of driver cards. One which drives stepper motors and one which
drives piezo motors. These cards can not be mixed within the same crate, but
can both be mixed with encoder input cards.
Thus an axis (motor) can either have an encoder connected or not and you can
have both combinations in the same crate.
I started out with a driver based on asynMotorController. But the type of axis
is hardcoded in this class, so I would need to code each possible combination
in a separate class. This would make the code very complex and hard to
maintain.
What I would like to have is a motor controller class where an axis can be
registered during startup of the IOC from the st.cmd file.
Did somebody face a similar situation before? If so, how did you solve this?
Any idea is welcome!
Jörn
RE: Motor record question Mark Rivers
Re: Motor record question Pearson, Matthew R.
Prev: Re: B21 Areadetector Mark Rivers
Next: RE: Motor record question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: B21 Areadetector [email protected]
ANJ, 02 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
