On 07/25/2018 06:52 PM, Matt Rippa via Tech-talk wrote:
> We commissioned a new RTEMS IOC here in Hawaii. The system ran
> for 2 days, 18 hours and 47 minutes before it simply halted. No exception was generated therefore no stack trace was seen. Also no console, no iocsh, no log messages. A system reset recovered our system before halting in the same manner 2 hours later. This occurred 4 times before the night ended.
> We speculate bad access or stack corruption but without a stack trace
> we're at a complete loss as to how to diagnose this. This *same software release* has run for several weeks at our other site with no issues.
> Is there a way to force an exception (or stack trace), for example with watchdog?
> Many thanks for your insight!
The only time I can recall truly seeing nothing printed during a crash was
when a hardware fault occurred. This was accompanied by a red fault LED
on the underside of the cards.
In every other case I can think of, including mistakes I made during driver
development, something was printed.
NSLS2 had a batch of mvme3100 cards suffering from silver creep corrosion,
which is related to the particular lead-free solder process used. In the
case of the mvme3100, we were told this only involved a small number of boards
assembled in 2011. We had boards assembled both earlier, and later,
which were not effected.
https://www.google.com/search?q=silver+creep+corrosion
This condition is very obvious under small magnification.
https://www.google.com/search?q=silver+creep+corrosion&source=lnms&tbm=isch&sa=X
- IOC Crash with No Exception Generated Matt Rippa via Tech-talk
Re: IOC Crash with No Exception Generated Andrew Johnson
<2018>
2025
2026
<2018>
2025
2026
